Starting new project
Old Dec 23, 2015 | 09:59 AM
6.9l dieselman's Avatar
6.9l dieselman
Hello all I'm starting a new project it's a 1986 Ford F-250 reg cab 6.9 diesel c6 trans xlt 3:55 rear I would like ideas on injection pump injectors turbo I want to make a mild hot rod and dd and do y'all think I should keep the c6 or go zf5 I'm looking for fuel mileage and power
Old Dec 23, 2015 | 02:41 PM
88 Ford IDI's Avatar
88 Ford IDI
A mild setup like you ate talking about would be a RD110 injection pump and stage 1 injectors. What turbo do you plan on running?
Old Dec 24, 2015 | 06:33 AM
6.9l dieselman
I have a turbo off of a 7.8l ford I was planning on sending to R&D to be rebuilt and upgraded for my spare Hypermaxturbo system
Old Dec 24, 2015 | 07:05 AM
6.9l dieselman
I'm finally getting started
Old Dec 24, 2015 | 07:45 AM
jayro88's Avatar
jayro88
I would get my pump and injectors from R&D as well. He has a couple of well documented builds with dyno numbers as proof.
For mileage, the zf5 will be the best. If you wanted to stay with an auto you could swap in an e4od or look for and auxiliary OD for your c6. Going the auxiliary OD route will be less $ if you shop around for a used unit, but the e4od will be a more efficient setup.
Old Dec 24, 2015 | 02:34 PM
6.9l dieselman
I have a 1990 f-350 that has a good zf5 bad motor I was thinking of parting it out and using the trans and flywheel from the 7.3 on the subject of aux trans I have one on my dd right now I like it but it's getting close to needing a rebuild and all my injectors and pump and cam and stuff like that is going to come from r&d
alexk3303
Ford Truck Parts for Sale
Dec 22, 2015 03:08 PM
A/Ox4
Nov 10, 2012 06:45 PM
Lil Red Sled
15
Jul 16, 2012 01:59 PM
PaysonPSD
32
Jun 29, 2010 10:35 PM
67nukeford
Nebraska Chapter
17
Feb 24, 2009 09:12 AM
