Water Pump Replacement Questions
Old Feb 14, 2002 | 01:49 PM
lanero's Avatar
lanero
OK people, here's the deal. I need to replace my water pump. The original factory pump finally gave out after 135,000 miles, you think Ford could make these things last a little longer.
Here's my question: Once I have the old pump off, how much more work is it to replace the timing set? This is on an '89 F250 with the 5.0L. The main reason I ask is, I don't want to have to do all of this again in 6 months if the timing chain goes out. If it is just going to be about another hour of work, I think it would be good insurunce to just go ahead and replace the timing set.
Thanks.
Roger Lane
Old Feb 14, 2002 | 03:16 PM
bjoern's Avatar
bjoern
That depends on the state of your bolts holding the timing cover in place (especially the ones next to the coolant passages). They have a tendency to get stuck and then it might take quite some time to get them out (if you have a torch!). I got some pictures on my webpage (see sig) on how it might look if you get two stuck bolts.
If you're sure that's not a problem, it's not a big deal and could be done in an extra two hours I'd say.
Old Feb 14, 2002 | 04:17 PM
whistler's Avatar
whistler
