Cranked up the timing a bit...
That's good to know you checked some of the electrical before doing the timing. I did a lot of timing work (testing different degrees) a few months ago, and the major difference between a few degrees was mostly MPG. So, be sure to keep track of your position relative to a neighboring component, so that you can return your IP to the original position if your MPG goes to hell.
Here's my video I made back then:
Timing a 1988 Ford E250 Econoline Club Wagon 7.3 IDI with Hypermax Turbo - YouTube
You should really use a meter too, cuz it's good to know exactly where you are. No matter how good you are with eyeballing it, just a 1/8" rotation can mean a big IP difference.
myoldvan
01-06-2014 11:10 PM
Vanzal15
07-23-2013 01:36 PM
powvey
09-18-2006 10:28 PM
