Blown hpop line... Again
Old Dec 16, 2015 | 02:36 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Hey guys so y'all might remember me blowing a line about two months ago or so. It happened again.
This time though, it was the pressure that blew the line. What pressure will I be seeing on the line going from the hpop to the head?? The one I had made should have been good to 3000psi... I thought our trucks only put out around 2900-3000 wot...
Stock hpop by the way.
Old Dec 16, 2015 | 03:13 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Not sure about a stock pump but my terminator will regularly run 3300. It would be best to have some live data on what your trucks putting out. Also I think I would find a hose rated for at least 4k. I would rather have a little extra than always pushing the limits
Old Dec 16, 2015 | 04:00 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I think 2800 with stock tuning. A chip can get more. A 3000psi line in my opinion is too weak. I would go with something at least 4000psi rated, if not 5000.
Old Dec 16, 2015 | 05:05 PM
Jarrett Campbell
I'll post a picture of the blown line when I get a chance. Also, does the line have to be steel braided?? The guy at Napa said his line wouldn't be a permanent solution because it was a rubber hose.
Old Dec 16, 2015 | 06:04 PM
MOOSE_MACHINE
Rubber hose to 3000 psi?
Old Dec 16, 2015 | 06:10 PM
Jarrett Campbell
The first replacement (blown today) was a stainless braided for 3000. The one I got today is rubber up to 6000. But the guy at Napa said this 6000rubber hose wasn't going to hold up in the heated environment of the engine bay.
Old Dec 16, 2015 | 08:53 PM
oldbird1965's Avatar
oldbird1965
I don't like promoting this guys business but I have a set of these and they are rated at 5000psi.
http://www.dynoproven.com/parts/ford...pop-lines.html
Old Dec 16, 2015 | 09:18 PM
rickdavis81's Avatar
rickdavis81
I had Hyspeco make some from parker hose for me. 4000psi rating and a pretty high temp. The highest parker makes if I remember right.
Old Dec 16, 2015 | 10:32 PM
fordpride's Avatar
fordpride
Hydro hose have two different ratting. You have a continuous psi rating and a burst rating.
If 3000psi was the burst rating then the continuous is around 1800-2000psi.
When having lines built you want to do a minimum of 4000psi continuous and have them done at a hydro shop. Not the guy at the local auto parts store.
Look at it this way. A tire rated for 65psi will probably hold 80psi but when you start working it how long will it last ?
Old Dec 16, 2015 | 10:40 PM
fordpride's Avatar
fordpride
This is the hose I use. I had a set built on a 97 I had. They had well over a 100k on them with out one issue
http://www.gates.com/products/automo...ire-braid-hose
Old Dec 17, 2015 | 07:47 AM
Bob_T's Avatar
Bob_T
I haven't had any problems with mine so I haven't messed with them. Just wondering if steel tubing with AN flare ends or Swagelok fittings would work?
Old Dec 17, 2015 | 07:53 AM
rickdavis81
When I was looking into new hoses I saw a setup a guy had using stainless and swedgelock. Looked slick and he'd had it awhile. If I blow another that's the route I'm going
Old Dec 17, 2015 | 12:06 PM
Jarrett Campbell
Well it's looking like I'm going to have to shell out the big bucks... No hydraulic shop in town has anything steel braided rated for anything over 3k.. Since I plan on doing the t500 at some point in the future, I'm not thinking those are going to work. Oh well. I tried to go cheap and look where it got me.
Old Dec 17, 2015 | 06:27 PM
fordpride's Avatar
fordpride
HPOP Stainless Braided Line Kit - Ford 7.3L Powerstroke
Old Dec 17, 2015 | 09:27 PM
oldbird1965
If it was me I would get the ones I posted. Oh, that's right, I did get them! LOL They are bigger in diameter and hard to get on with the bends but I think worth it.
