New to me truck blues
So as I under stand it i insert paper clip, turn truck on engine off and it will give me codes, then when there is a 9 sec delay the next set of codes will be from CM, after I get those I can start the truck and after it flashes once turn wheel left then right then apply brake the rev motor one time, it will the start giving me key on engine running codes.
This is all seculation on my part, so please chime in if I have been misled.
Thanks Guys
Thanks Guys
Thanks Guys
Thanks Guys
There are many factors that contribute to "performance", especially the butt-o-meter. Engine size/state of tune, gearing, tire size, lifts, etc. are the biggest contributors. It would not be a surprise to find you have 3.08 or 3.31 gears so operation in O/D is going to very sluggish. Even 3.55s in a 5L truck are a bit skimpy.
Check the door tag for the axle code.
#29
#30
it has a 95 Mustang 5.0 long block with 70k miles running on 31x10.5 AT tires.
leaving a stop light feels normal, I am 51 , so i am not racing it to each light. But when i am at hwy speed, i have to tell the passenger that i have just floored it, that is no exaggeration, it is literal. When floored at 65 it gains speed at about 4-5 MPH each minute, and that is after it drops down out of O/D, which CANNOT be felt in the seat of your pants, but heard if you listen to the motor carefully. it is very quiet.
