Winter weight.
Old Dec 15, 2015 | 12:28 PM
hoseclamp's Avatar
hoseclamp
Winter weight.
Added 1/2" to the 3/4" x 48 x 96 plate I used in my f350 tow boss. With the 1"x 48 x 16" header to keep the plate from cutting ppl in half if rear ended, 1,850lbs. Canopy is around 300lbs. Fender height front and rear on my
450 are identical. Rides nice and smooth! Still no sidewall pooch on the rears at 65psi though. Front is good at 85psi.
Old Dec 15, 2015 | 01:54 PM
djousma's Avatar
djousma
Holy crap! I see how you got it in there, but how will you lift it out?
Old Dec 15, 2015 | 01:55 PM
System's Avatar
System
Prolocutor
Same way I'm guessing...
Old Dec 15, 2015 | 02:06 PM
djousma's Avatar
djousma
Yea, but its not like you are going to get a crowbar under a 2000# plate very easily to facilitate getting the forklift blades under. Should have welded on a couple of lifting points while you were at it. All I can saw is WOW.
Old Dec 15, 2015 | 02:14 PM
hoseclamp's Avatar
hoseclamp
Easy to lift with crow bar no problem, get the forks under, hook the chain, drag back until it hangs off the tailgate 6-8", fork in all the way, chain up, store it for the next season
Old Dec 15, 2015 | 02:17 PM
djousma's Avatar
djousma
see what I know....nothing. Nice bit of engineering!
Old Dec 15, 2015 | 02:18 PM
System's Avatar
System
Prolocutor
I want a forklift.
Old Dec 15, 2015 | 02:28 PM
hoseclamp's Avatar
hoseclamp
No worries Dave! And having heavy equipment is good. The down side is you want them all and keep building shops to store everything. Lol. I have 4,600sq ft in the house and 15,000 in shops at home. Lol.
Old Dec 15, 2015 | 02:29 PM
baerpath's Avatar
baerpath
Originally Posted by Karl4Cat
I want a forklift.
The heck with the fork lift I want the weight
Old Dec 15, 2015 | 02:32 PM
System's Avatar
System
Prolocutor
Now, let's not limit ourselves. We can have both...
Old Dec 15, 2015 | 02:42 PM
baerpath's Avatar
baerpath
I could put this in the bed again, truck handled it fine I like the plate better !
Old Dec 15, 2015 | 02:44 PM
hoseclamp's Avatar
hoseclamp
Plate would definitely be better!
Old Dec 15, 2015 | 02:48 PM
System's Avatar
System
Prolocutor
And take up a bit less space.
Old Dec 15, 2015 | 03:16 PM
suzuki0702's Avatar
suzuki0702
WOW! i love it!. When i plowed with my 04 i used to put a 1yard inget concrete block in the with ratchet straps....this is by far superior!!
Old Dec 15, 2015 | 05:24 PM
dualwheels66's Avatar
dualwheels66
Hoseclamp, be sure to come and visit over in the dually's only section
