Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Support Bearing
Old Dec 14, 2015 | 09:54 PM
Sharkster54's Avatar
Sharkster54
Exclamation Support Bearing
Hey guys..
Does anyone here have instructions on changing the drive shaft support bearing on a 2006 Ford Escape 3.0? Mine is growling like mad..
Links and/or pics would be a great help...
Thank you...
Old Dec 14, 2015 | 10:13 PM
bmuhlbach's Avatar
bmuhlbach
I did mine a while ago pretty easy to do. I bought the new bearing and did the u jionts at the same time. Didnt take any pictures.
Old Dec 16, 2015 | 04:46 PM
Dan Robertson's Avatar
Dan Robertson
I changed out mine on an 05. It wasn't a bad job at all. The dealer was no help, wanting to sell the whole drive shaft but Car Quest (now Advanced Auto) sold me a Doorman brand that came with a life time warranty. It came with the entire cross member, made the job a lot easier.
Old Dec 16, 2015 | 09:21 PM
pcarr4's Avatar
pcarr4
It's not a bad job. Make sure you mark the orientation of the yokes. You'll split the u joint, take the nut off of the Yoke. Make sure you mark both the yoke and the shaft so it goes back on In the same spot. Pull the yoke and bearing using a puller. Slip the new carrier bearing on and you can use the yoke and nut to press the bearing onto the driveshaft. It's not too bad of a job.
Cavstoy
May 30, 2012 09:40 AM
Jmartin1108
13
May 8, 2011 10:23 AM
nflfreak43
20
Jun 19, 2010 05:25 PM
jrlowscot
May 8, 2010 01:00 PM
Ed in Maine
Nov 18, 2007 03:37 PM
