Excursion Wheel/Tire Sizes
Old Dec 13, 2015 | 08:52 PM
WE3ZS's Avatar
WE3ZS
Look up top in the Tech Folder for articles on the V/B code swap (Super Duty springs) they will give almost 2" of lift and a set of 285/75R16s (33") wouldn't look too bad.
This thread has lots of different spring/lift combos with various tire sizes, it makes for good reading for anyone looking to modify their EX suspension.
https://www.ford-trucks.com/forums/1...easurents.html
Old Dec 14, 2015 | 03:46 PM
harley4jcs's Avatar
harley4jcs
Originally Posted by Excursion Fan
Thanks so much for all the info. Got a lot to think about now.
Drunken Unicorn asked about gearing. We have 3.73 and I doubt the Ex will ever do much, if any, towing.
We don't really want that huge gap that seems to come with a 4" lift and not doing 35s or taller. What's everybody's opinion of doing a 2 1/2" SD suspension lift, 16x9 wheels, and staying with the original 265/75/R16s.
Thanks again
X FAN & Pirate 4X4 :: Here are some pics & dimensions for you 2
X FAN: here are 3 XXX's ,White one on right stock on 265/75/16's, Stock wheels.
White one in middle has V-codes in front 265/75/16's, Stock wheels.
Blue one on the left has 4" pro-comp S/D lift with 16.5/9.75 wheels & 37" tires.
The key to fit on the X, S/D front is the inner fender & fender lip at the back of the tire. The 265's on stock wheels are about 30 1/2" tall. The Stock X has 4 1/4" gap at the inner fender & can touch if driven crazy, The V-code has 5 1/2" at this spot with the 265's, The 4" lift & 37's nets only 3 3/4" at this spot & is fairly easy to make contact & you can see in the pics it's no big deal & the plastic can be trimmed if desired. A 9.75" wheel is going to be two wide for a 265 & if you do the V's a 9.75"/ 33x12.5 Tire will be a great match.
Pirate : I don't think you can go lower W/O cutting or cutting & flares PLUS the coil frontend should have the tire inset more than the leaf set up in the pics.
Old Dec 15, 2015 | 07:20 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Sweet,
My front axle housing is still the Dana 50 but I plan to swap in a 06 Dana 60 from a coiled truck. My 4 link and coil setup is from Fabtech not ford. If I ever get around to putting in the new axle ( have been waiting to break mine again ) I want to lower mine as low as I can get it ( with out steering components hitting frame or engine bits ) and then alter the fenders for clearance as needed.
I had an 06 with a 60 pickup that was lifted 4" ( 6" ex ) that I ran 40" tires by running fiberglass fenders with bigger wheel arches and it worked out great.
Anyhow, I like how the your Ex sits on 37's with the 4"
Old Dec 15, 2015 | 07:21 AM
harley4jcs's Avatar
harley4jcs
Thanks again
17X9 with 33 X 12.5 X 17 will work very well also.
JerzeyBoi
Nov 20, 2016 11:24 AM
jfxwave
May 9, 2011 05:14 PM
TCExcursion
Aug 16, 2009 03:21 PM
mcjones44us
Mar 27, 2008 02:29 AM
keithsford
Dec 2, 2003 10:54 AM
