Official NCFTE Works Thread
#3046
I have 2 sets of wrenches in my wrench drawer, and enough loose pieces to fill up a separate drawer. I keep those down at the very bottom, to be used whenever I lose a wrench. And all the wrenches in that bottom drawer got rust on them! I think maybe the humidity is much worse the lower you are, I have lockers in my shop as well as the bottom vents are completely rusted while the tops look fine.
#3048
#3049
ironically. The new push mower the parents bought didnt last 20 minutes before the engine blew up it a puff of smoke lol
#3050
Well I'm currently at a stand still as USPS gives my package with carb gasket kit and new power valves a tour of the state. Normally my packages go Greensboro Fayetteville to Swansboro. So far they've went Charlotte, Fayetteville, Wallace... they show of been here last Thursday but now say Tuesday so who knows... meanwhile my carb is setting...
#3051
#3052
#3053
#3054
I felt the AC in the pick up not blowing as cold as it should.
Also when I would come to the light it would start blowing warmer.
Put the gauges on and found the low side at 25 PSI, a little low in my book.
I dont remember now what the high side was.
When I went to give it more charge I found the sight glass on the gauge set leaked
I have only used it a hand full of times but guess that all you get from HF gauge set back to
I was able to get the low side up to about 50 PSI.
Think it blows colder but it is also cooler out so time will tell.
I also bought a plastic welder, heat & blower as 1 tool.
I used it to weld my garden tractor side panels together of what parts I have of them.
I still need to do more work to them before I can install them back on the tractor.
Dave ----
Dave ----
#3055
Dave ----
Dave ----
#3056
#3057
I am still working on the panels as they still need tabs made and welded or glued on.
I was thinking of working on them tomorrow but you reminded me of the Four Oak's show.
Also thinking of how I can make the tabs as they were missing when I got the tractor.
Dave ----
#3058
Dave is your plastic welder something like this:
https://www.welfirae.com/products/45...RPUzLsCE5ZLoQc
#3060
Something you would buy for a specific job and that would pay for itself, then sit in the cabinet until the next time something comes up.
