How???
Jun 16, 2017 | 08:08 AM
How do water heaters wear out?
Jun 16, 2017 | 09:52 AM
How they rust from the inside makes you wonder why they don't have a ceramic lining in them..
Jun 16, 2017 | 11:48 AM
How is it that they have a metal rod in them that you are supposed to replace every so often, and nobody does?
Jun 16, 2017 | 12:41 PM
How come the old ones are always so heavy when you take them out?
Jun 16, 2017 | 04:18 PM
How come you didn't drain the water..?
Jun 19, 2017 | 08:31 AM
how often do you drain your tank? I have heard you should drain them every year or so.
Jun 19, 2017 | 10:07 AM
How come I never think of draining mine on a regular basis, maybe they would last a little longer..
Jun 19, 2017 | 04:46 PM
How come when you try to rain them the drain plug is clogged up with gunk from inside the tank and there is always 10 to 15 gallons of water in a 50 gallon tank.
How come 15 gallons= about 120 pounds plus the weight of the tank?
Jun 20, 2017 | 08:01 AM
How does that much junk end up in the bottom of the tank?
Jun 21, 2017 | 08:29 AM
How do you change the anode rod?
Jun 21, 2017 | 07:01 PM
Jun 21, 2017 | 07:03 PM
How come I've never heard of this before, I might have had my heaters last longer...
Jun 22, 2017 | 09:02 AM
How come it looks easy without the heater hooked up to the water pipes and wiring and out in the middle of a room?
How come my heater is stuck back in a tight corner where it will be a pain to change the anode?
Jun 22, 2017 | 06:10 PM
How I'd have to remove the tank to do it..
Jun 22, 2017 | 07:56 PM
How come their heater is nice and clean without corrosion (locked tighter than hell) on the anode threads?
