Power for ignition?
Old Dec 10, 2015 | 06:59 PM
No704's Avatar
No704
Power for ignition?
73 360. Pulled the used up ford crap out, installing a gm style hei dizzy. Where is the hot run and crank source for dizzy and choke?? Thanks.
Old Dec 10, 2015 | 10:41 PM
No704's Avatar
No704
And why woul eldebrock not recommend hooking up choke power with ign power?
Old Dec 10, 2015 | 11:04 PM
84espy's Avatar
84espy
You will want to run a wire from the starter solenoid to the coil. This will be the 'I' post, I believe. It will give you power while the starter is on. You will also want to run a wire that is hot when the key is in the run position to your coil and choke. If you still have the original wires from the Duraspark module, these can be used. I ran my own wires using 12ga. I love my HEI unit on my 460.
Old Dec 11, 2015 | 03:57 PM
usuallybowtie's Avatar
usuallybowtie
In my 75 I used the red wire with thin white stripe to trigger a relay to send 12v from battery to dist. I could have just ran it direct to the distributor but I felt like keeping any load strain off of old wiring and the ignition switch. Found another wire that tested as key-hot only and used it for choke. It appears to be red with yellow stripe but it is faded. All these wires were in the bundle coming through my firewall just above passenger side valve cover.
Old Dec 12, 2015 | 02:02 PM
No704's Avatar
No704
So I need to tap both a run and a start wire and isolate wth diodes?
Old Dec 12, 2015 | 06:17 PM
84espy's Avatar
84espy
I didn't use diodes. I ran both wires to the same contact point.
cyris426
Nov 22, 2012 09:10 AM
bluegoose95401
Aug 22, 2012 08:48 PM
BigShelby
Electrical Systems/Wiring
Jun 10, 2007 12:05 PM
30over
Jan 16, 2006 09:41 PM
Ron
Nov 10, 1999 01:04 AM
