Engine Temp Fuel Filter flash
Old Dec 8, 2015 | 01:55 AM
F350XLT's Avatar
F350XLT
Hey Guys,
i have a new proplem with my Truck.
When i start the Truck the engine temp and fuel filter lights go on and the Truck crank and hard to start.
I have two broken sensors ICP and map sensor.
I hope you can help me.
More Information:
I have a lot of white smoke the engine wiring...fuel filter is new glow plugs are new the fuel pump is new.
glow 4 or 5 times on 0c° and the engine wiring.
OSD say 124/125 codes.
Thanks and nice Greetings from Germany
Old Dec 8, 2015 | 10:31 AM
madpogue's Avatar
madpogue
If you're saying those lights go on while you're holding the key in the START position, that's the bulb check. It's documented in the owner's manual.
If, by "glow 4 or 5 times", you mean you're cycling the key off and on that many times, when the WTS light turns off, then you're wasting your time and wearing out your GP relay. The GPs run long after the WTS turns off. If you want to extend GP run time before starting, just leave the key in the RUN position for an extra 10-20 seconds.
How have you determined that the ICP and MAP sensors are "broken"? Do you have a way of reading live data from them?
So there is wiring in the engine compartment that is smoking? That is BAD! You need to be more specific about which wires.
What is "OSD"?
Old Dec 8, 2015 | 02:44 PM
F350XLT's Avatar
F350XLT
Sorry my Truck is from the US Air Force here in Germany i became the Truck without a Owner's manual
yeah right so i glow 4 or 5 times but ok not any more
I had a Diagnostics Tool from a Friend and see the Ford Codes 124/125 and at Work i test it with our Bosch Tester and become the same Codes on live testing the complete Truck but no way for live testing any sensors in a diagram.
And the ICP is full of Diesel
no i have a lot of white smoke on the back from my truck when i will start.
Old Dec 8, 2015 | 05:44 PM
97-psd's Avatar
97-psd
The ICP probably has oil instead of diesel in it. You will need to get that replaced. When you turn the ignition on watch the voltmeter. It will be low when the glow plugs are on. Once the needle jumps up it signifies that the glow plug relay has cycled off. Then try to start the truck
Old Dec 8, 2015 | 05:45 PM
97-psd's Avatar
97-psd
Sounds like you may have more than one issue. We will do our best to help you work through them
Old Dec 9, 2015 | 07:28 AM
F350XLT's Avatar
F350XLT
What i not understand is i have only hard starts the Truck stands a long time 4-5 hours he crank at start up and stand one night hard to start.
My oil level is at half and the oil pressaure came last start up after 4 - 5 seconds after start up.
I think i have a sensor problem because he becomes fuel (white smoke) but is it only the icp?
Ok last time i start the Truck:
Glow...wait 10 or 15 seconds...start...nothing...i disconnect the icp...glow...wait 10 seconds...start...run after 2 or 3 starter turns...
I'm confused...
should I make a video from the start up?
Old Dec 9, 2015 | 09:06 PM
ReBilld's Avatar
ReBilld
Welcome to FTE! Sounds like you may have some bad glow plugs and/or glow plug relay. Next time you try to start the truck, turn the key on and wait at least one minute before you try to start it, and see if it starts any better.
Old Dec 10, 2015 | 01:50 AM
F350XLT's Avatar
F350XLT
Thank you!
The glow plugs and GPR are a half year old.
I have done what you say with connectet IPC nothing so i disconnect the IPC glow and wait 30 seconds 3 or 4 startet turns and the truck run.
Old Dec 10, 2015 | 07:33 PM
ReBilld's Avatar
ReBilld
If the ICP sensor has oil in plug, it may be bad. May have to try changing that sensor.
jgrohs54
22
Jul 19, 2017 09:36 AM
powerfan99
17
Jan 1, 2013 09:43 AM
kyflaresideon20s
Oct 21, 2011 04:41 PM
turboboost
May 12, 2009 08:06 PM
deleontow
Dec 31, 2000 04:39 PM
