Excessive Fuel Use
Old Dec 7, 2015 | 09:32 PM
njjr's Avatar
njjr
Excessive Fuel Use
Have a 1989 F150 4WD Standard 4 speed with overdrive. Been sitting for a number of years and had to put a new fuel tank and pump on it.
Took it for a test drive and noticed the check engine light came on intermittently. Drove it 40 miles and noticed the fuel gauge seemed to start moving down pretty fast. Refilled the tank and it took 7 gallons of gas. That's 5.5 miles a gallon.
The tank nor the lines are leaking.
So what could cause this. The engine runs smoothly except when using cruise control. With cruise control it feels like it is missing slightly.
Truck has 67,000 original miles on it. I know this because it was handed down to me by my deceased Uncle.
Old Dec 7, 2015 | 10:05 PM
Conanski's Avatar
Conanski
Single or dual tank truck?
Pull the codes and post them up.
Check fuel pressure and post up the results.
Old Dec 7, 2015 | 10:56 PM
twigsV10's Avatar
twigsV10
The fuel pressure regulator is a possible culprit especially with prolonged sitting, the internal diaphragm can become brittle and crack letting fuel into the vacuum system.
It's easy to check and will likely be accompanied by a rich code at low engine loads. Turn the key to run for several seconds WO starting to prime the fuel system then pull the vacuum line off of the fuel pressure regulator and it should be dry.
I don't know if this is actually your problem but it's something I have seen be a problem even on newer vehicles that sit for long periods of time.
jerrdan98
May 2, 2017 09:32 AM
cajunsuperduty
Jun 29, 2013 10:12 PM
albacore26
May 10, 2012 08:55 PM
79Ford4x4
1983 - 2012 Ranger & B-Series
20
Aug 28, 2011 12:59 PM
Delbert_Gardner
Aug 2, 2009 06:26 AM
