1978 - 1996 Big Bronco
Spindles and bearings
Old Dec 6, 2015 | 08:58 PM
dirtcowboy's Avatar
dirtcowboy
I'm in the process of rebuilding spindle and hub bearings from either an F-150 or FSB. The problem is the new Timken bearings won't slide onto the spindle. The old bearings do, snugly, but the new bearings are getting hung up and just won't go on. I did a light clean up with emory cloth but still no joy. The old and new bearings have the same part #'s on the bearing, JBG sells them as type 37 inners. The new type 45's, outers, do fit correctly. Suggestions??
Old Dec 9, 2015 | 07:20 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Had some issues with a Timken throwout bearing recently. It wasn't the correct part in the box according to what was pictured (tried twice - both wrong). Ordered one from National and it was correct. I'd try another brand and see what happens.
Old Dec 10, 2015 | 03:01 PM
dirtcowboy's Avatar
dirtcowboy
I finally got a little time so I took the spindle, old Timkin bearing and the new Timkin bearing into my local NAPA to show them to a really saavy parts dude. He futzed with it a bit then, all of a sudden, the new bearing "clicked" onto the spindle. He pulled it back off and repeated the futzing until the bearing clicked on again. Note, when removing the bearing, it just slid off, no problem! Success!! I took my prizes home and repeated the process using a large, long, socket, YAY!! I then turned my new rotor and hub over, installed the bearing with a little grease to hold it in place. I installed the spindle and with two light taps from my 32 oz ball peen hammer, another seating!! I then sat the hub and rotor right side up and slid it over the spindle. Now with the weight of the hub and rotor to help it took just one light tap and the unit seated.
Sooo, it appears the Timkin bearing will seat as it appears there is some sort of friction fit but not a press fit.
We also tried the SK brand bearings, the NAPA brand bearing and two chinese version of the bearing and got them all to fit with a bit of persuasion as well.
Thanks for the responses!
Old Dec 10, 2015 | 10:12 PM
My4Fordtrucks
That still does not appear to be right to me but if you are satisfied with it...
Old Dec 10, 2015 | 10:19 PM
dirtcowboy's Avatar
dirtcowboy
After none of the other bearings fit any better, I just kept the set I had paid for. We shall see, I guess, but I will post up any future issues.
Old Dec 11, 2015 | 10:48 PM
dirtcowboy's Avatar
dirtcowboy
Rooting around on the interwebs I found this, step 24;
Wheel Bearings and Spindle Bearings - FSB Forums
scottddove
Aug 12, 2015 12:48 AM
xxl_2321
1997 - 2003 F150
Dec 26, 2010 08:55 AM
yotazuki
Aug 1, 2009 09:46 AM
kbarger1
Apr 11, 2007 12:06 PM
Steve_Uzi
Sep 12, 2003 08:59 PM
