New engine?
Old Dec 10, 2015 | 02:56 PM
Todd1577's Avatar
Todd1577
I had / have the same similar issue with my V10 Ex but it would not bubble out the coolant jug. it would hydro lock the engine. Put some head gasket/brock sealer in it and it lasted about a year and a half before it did it again at which time I bought some better stuff and it has been in it for about 9 months now with no issues. Eventually I will do a full rebuild on the engine but with 196,000 miles I don't see putting new head gaskets on a engine with that many miles on it. I used to get the milky oil filler cap and have to add coolant form time to time but since I did it the second time I have not had those issues anymore. I do have the head gasket set and will be getting a new timing chain set I just hate to do all that and then something goes out on the bottom end.
Old Dec 10, 2015 | 03:30 PM
05MilMachine's Avatar
05MilMachine
From my reading, the bottom end is stout if cared for. However if it has been ran with moisture contamination for any length of time all bets are off and a full rebuild might be best. I experimented with block sealant on my 04 Mountaineer and had very limited results. Ended up swapping in a used engine. When I pulled the heads off to see what went wrong, you can see how that sealant works...and lets just say, it makes a big mess and I won't experiment anymore.
Old Dec 15, 2015 | 12:21 PM
Sherman Manley's Avatar
Sherman Manley
Pulled plugs today. In prep for compression test.
Most looked like picts above and below this one. This one looks diff. It is rear most pass side.
The rest look like this. They are about a month old.
Old Dec 15, 2015 | 12:27 PM
Sherman Manley
So pulled plugs in route to doing compression test today. I am in Glenn dale md if anyone with experience wants to lend a hand and maybe a tester so I don't have to buy.
How I wish it were just in need of the it Italian tune up lol.
Old Dec 15, 2015 | 12:51 PM
Todd1577's Avatar
Todd1577
I believe AutoZone rents them out. I could be wrong though.
Old Dec 15, 2015 | 03:36 PM
Sherman Manley
Ok got my compression guage. BTW the auto store around my area are terrible. They don't even bother to look for the rental tool. In fact it's funny how many eye rolls I got just asking for a rental tool.
It took 4 store until I could finally get someone professional enough. Then I just bought the darn tool.
Anyway what am I looking for pressure wise
Old Dec 15, 2015 | 03:42 PM
harley4jcs's Avatar
harley4jcs
160 -180 I THINK but more than anything you are looking for them ALL to be with in 20 PSI of each other.
Around here there are no rental tools, You buy the USED tool & then return it...
Old Dec 15, 2015 | 03:45 PM
Sherman Manley
Yeah they put them in sealed plastic so they know u opened them around here. They would probably give me the eye roll again. With a neck shaking uhuh
Old Dec 15, 2015 | 03:48 PM
Sherman Manley
Thanks for the info here is my procedure.
Remove filter
Remove all plugs and coils. Disconnect all fuel injectors
Screw in guage hand tight and turn her over a couple times.
harley4jcs's Avatar
harley4jcs
Not what I meant. The rental fee is the cost of the tool & you have something like 20, 30 days to return it...If you don't, you own it.
Old Dec 15, 2015 | 03:50 PM
harley4jcs's Avatar
harley4jcs
160 !!! Should be a good #.. Now, where are the rest !!
Old Dec 15, 2015 | 04:12 PM
Sherman Manley
Got this
And this in two adjacent cycinders is it ok?
Old Dec 15, 2015 | 04:13 PM
  #28
Sherman Manley
The rest so far are around 175
Old Dec 15, 2015 | 04:16 PM
  #29
Sherman Manley
Also called parts yard 1500 for a 160000mi motor!!
Old Dec 15, 2015 | 06:49 PM
  #30
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
A spread of 20 is what you're looking for. Low numbers in adjacent cylinder cylinders could indicate a leaky or bad head gasket amidst other things.
Don't go for that junker motor. If this is the only issue yours is having, you can be up and running for less than $300 parts and fluids.
