yet another question
Old Aug 6, 2003 | 08:28 PM
bob-63-292's Avatar
bob-63-292
I'm removing my cab to get it media blasted (if I can figure out how to get the steering wheel off).
Question: the guy doing the blasting primers it as well. Should I let him spray the primer before I put on the filler or after I put on the filler (just had the floor replaced and need to fill in some weld gaps)???
Bob
Old Aug 7, 2003 | 03:48 AM
Aekisu's Avatar
Aekisu
<cr>
Depends on the primer.
If he is using lacquer primer, wait to get the filler work finished.
If he is using epoxy primer, spray the primer and then do the filler work.
