05 broken valves?
Old Nov 29, 2015 | 11:46 PM
srpservices's Avatar
srpservices
05 broken valves?
i have an 05 f150 that quit while driving, towed it home n started it up but was running rough n noisy in the front of motor. figured it jumped time n i would put a new timing set in and phasers. upon removal of passengers side valve cover i found 1 rocker out, 1 broken and 1 off the valve spring with a bad roller. the keepers were off the valve and the valve is in the cylinder. timing chain is very loose and there is a broken piece down in towards crank sprocket. did the timing jump cause 3 rockers to be damaged n 1 broken valve all in one cylinder. havent removed the drivers side.
was looking for parts to repair and they seem to not be many options out there for the 3 valve motor.
thanks scott
Old Nov 30, 2015 | 12:10 AM
srpservices
it is a 5.4 in a f150 4wd.
Old Nov 30, 2015 | 01:23 AM
thzpcs's Avatar
thzpcs
It definitely jumped if it is loose and toasted all your rockers like that. You can check where TDC is vs the valve position by hand cranking the motor.
Old Nov 30, 2015 | 02:45 PM
Leroy Axe's Avatar
Leroy Axe
Pull the timing cover(easy with the valve covers off.) You will probably see the timing chain guides broken.
The head need to come off also a this point, at least the one that dropped the valve.
Its wise to pull both, check the valves on both heads, have them ground, new guide seals etc.
Reassemble with all new timing components
Old Dec 1, 2015 | 07:23 AM
davidzog's Avatar
davidzog
How many miles did you have on that truck? Also, what kind of oil and filter did you use?
Old Dec 1, 2015 | 02:31 PM
srpservices
it has 200,000 on the truck. i dont know what kind of oil n filters that were used for sure. i just bought the truck as it is fairly cheap to fix n drive. the guy i got it from was very up front on telling me what it did when it quit. he said he only used royal purple oil not sure what he said for filter. but that has only been for 70,000 miles that he has owned the truck.
i think i need more than just the head repaired. i cant imagine a whole valve laying on top of the piston did it any good.
thinking i need to find a good used motor and do the timing chain n phasers along with plugs. i see the used ones i have found are kinda pricey.
still going to pull the motor and see what all damage is there.
any body know of a good source for engines n parts
thanks scott
Old Dec 1, 2015 | 05:12 PM
Leroy Axe's Avatar
Leroy Axe
Now that you mention it, if you dropped a valve it may have damaged the pistons
Bought my engine for my 07 from powertrain products in Maryland a month ago.
3500 bucks with a 4 year unlimited mileage warranty.
Napa sells the same engine
Remaned in mexico.
it is awesome. superquiet. Runs excellent . Machine work looked great
Heads were both machined for cam bearings and had them installed.
They are also using the newer melling Hi vol oil pump
Sounds like a new one would be your best option.
79F250RepoTruck
Mar 23, 2012 08:37 AM
blueovalpaul
32
Jan 13, 2012 08:31 PM
RobbyMartin
2004 - 2008 F150
28
Jul 8, 2007 12:02 PM
poboy
Jul 19, 2006 02:46 PM
ford_nut
Apr 21, 2002 06:11 PM
