Ford P350 questions
Old Nov 24, 2015 | 02:32 PM
Jim Collier's Avatar
Jim Collier
Ford P350 questions
Can anyone explain why my P350 has a 130" wheelbase when the 1948-1956 ford parts catalog says all the "J" P350 are either 104" or 122" I am having a hard time trying to figure out exactly what I have here and also has anyone hunted down a supplier for the curved glass pieces for one of these
Old Nov 24, 2015 | 03:55 PM
52 Merc's Avatar
52 Merc
Perhaps it was a special order and was built on the P500 130" wheelbase chassis with 350 running gear? Delivery vans were available in several configurations. Some had a Ford body, or a partial Ford body/cowl, or just a plain chassis where the body manufacturers would build their own body complete. That appears to be what yours is, so it won't have any Ford supplied body parts, including the glass. You'll need to track down body maker info to find replacement glass. Or have it custom made($). What year is it? What does the VIN say?
Old Nov 24, 2015 | 04:13 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
You've defeated my references too. The 130" wheelbase would be right for a later P-500, but you have the lighter duty single style wheels and hubs of a P-350. Either 104" or 122" per the books. Stu
Old Nov 24, 2015 | 07:12 PM
Jim Collier
So confused!
ok so the brake parts should be from the p350 is what you're figuring?
Old Nov 24, 2015 | 07:16 PM
Jim Collier
Vin markings?
anyone know where all the vin markings are located on this beast?
Old Nov 24, 2015 | 07:46 PM
52 Merc's Avatar
52 Merc
Are there any body tags on it? It appears to be a Grumman Olson. They should have a tag on it somewhere, and sometimes the body builder tags have the chassis vin stamped on them. You might check with these guys; Grumman | Skunk River Restorations
It looks like they did a nice job restoring one,
Old Nov 24, 2015 | 10:53 PM
truckdog62563
In the picture it's pretty clear you have shallow dished single style wheels. Probably 17", my guess, which creates for you its own set of challenges. If I'm correct they are 17", not 16", they are two piece called Firestone RH-5°. Known today as "widow makers". Next question, what is the bolt pattern? Six on 7.25", or 8 on 6.5"? Stu
rbell0
2004 - 2008 F150
Feb 6, 2008 11:34 AM
oldblue18
1978 - 1996 Big Bronco
Jun 12, 2001 07:21 PM
Josh
Jan 10, 2000 12:28 PM
