Steering wheel controls
Old Nov 23, 2015 | 01:26 PM
jpcjguy's Avatar
jpcjguy
Hi,
So I have a loose wire to my steering wheel controls. They don't light up anymore and when I smack the back of the wheel, they will light momentarily. Also, 2 of the radio buttons work intermittently. How do I access them?
Thanks!
Old Nov 23, 2015 | 02:55 PM
Stewart_H's Avatar
Stewart_H
Go to the Excursion Forum Tech Folder sticky thread.
Scroll down to Interior > Electrical > OD Switch Chaffed Wire Fix 1
Stewart
Old Nov 23, 2015 | 03:03 PM
Stewart_H's Avatar
Stewart_H
Hope that helps a little.
Stewart
Old Nov 23, 2015 | 03:10 PM
jpcjguy's Avatar
jpcjguy
Thanks for the link. I will check this wire. I assume that once I have the covers off, I will be able to see the wires to the controls? and the controls themselves - From what I read, it is either the clock spring or could be the buttons themselves (previous owner pushing too hard). How can I get to the buttons?
Old Nov 23, 2015 | 04:15 PM
mecdac's Avatar
mecdac
Remove the SRS aka Airbag. Two torqs behind the wheel.
Old Nov 23, 2015 | 05:49 PM
jpcjguy's Avatar
jpcjguy
Does the wheel have to come off?
Old Nov 23, 2015 | 07:26 PM
mecdac's Avatar
mecdac
Depends on what you are trying to accomplish and the severity of the problem.
Old Nov 24, 2015 | 06:53 AM
jpcjguy's Avatar
jpcjguy
Well, I won't know until I get in there. If it is not the wires leading to the buttons, then I have to assume the button contacts themselves. That is why I am asking on how to access them - do I need to be prepared to pull the wheel and/or any other tools I need.
On another note, last night driving home, the lights for the steering wheel controls light up on right hand turns and then turned off when straightening out again. Is this indicative of a clock spring issue?
Old Nov 24, 2015 | 07:33 AM
mecdac's Avatar
mecdac
At this point I would think the wheel will have to come off completely.
If I were betting man I would bet your issue is the contact(s) between the wheel and the column.
Bruinzfan
Sep 11, 2018 01:53 PM
03PowerstrokeExcurs
Jan 24, 2017 04:11 PM
JaySVX
Nov 12, 2013 09:46 PM
71-4R3SONS
Mar 30, 2010 07:32 AM
Big_Dom
Feb 13, 2010 11:28 PM
