Grandpa's 55' F350 restore
#91
#92
Yep, it's an addiction!
You went all fancy on your seat. I just grabbed a drop cloth and covered mine when I had it. No padding at all.
I would be interested to hear oil suggestions as well. I wouldn't be surprised if it was all over the map though.
I've never heard of Archer Aircraft Oil, but it does have a cool can.
#93
Dropped the pan today to clean out the gunk. I found something that I need help identifying. It is a round tube, slightly bent and about 3" long. Probably the first time the pan has ever been off. Since I have never taken apart a 239 I have no idea what it is. At first I thought it was maybe a pick-up tube, but when I removed the screen it was obvious that it did not come from that. Also the screen was completely plugged with gunk. I plan on rebuilding the engine in the near future but thought I would clean it up in the mean time. Boy was I in for a surprise.
So a couple of guys (Thanks Dennis and Joe) helped me identify the tube. It is the drain back tube from the road draft tube canister filter. That must explain why oil has always leaked out the draft tube. I already had the pan back on and oil added so I will be putting the tube back in tomorrow. When I started the Truck after cleaning the pan and screen the Oil Pressure went to over twice of what it was to begin with. This was a definite positive step forward.
My research of oil types yielded about as many options as comments. I ended up going with Castrol 10W-30 and a Zinc additive. Not really a big deal since I plan to rebuild the engine sometime down the road. It sure seemed to run better after I changed it. When I gave it a little gas the pressure accually went up to 80 psi. When it drys up I'll take it for a little spin and see what it does.
For future reference - https://www.ford-trucks.com/forums/1...entifying.html
#94
I changed my oil after it had been in there a couple of years with only a handful of miles and it seemed to really help.
Get that rain moved on. I will be up on Saturday. I will start the morning at Pioneers Park for the cross country meet then go to the game. We aren't sure if we will stay in town Saturday or at least start back. Hotels are double the normal price on game days. Just normal trip to Lincoln for us, a whirlwind. Since Sam has homecoming friday evening, we will probably only get to Platte city or St. Joe Friday and get up at the crack of dawn to make it to the meet Saturday morning.
#95
Got a couple of things accomplished today. First I wanted to get the drain back tube from the road draft tube canister filter welded back on. Evidently it was installed before it was attached at the factory. My welder guy had to insert the base plate in the cartridge body before he welded it. Otherwise I would not have been able to insert it in the hole. It's great to know talented people! I also stopped at a local shop that had advertised Ford 53 - 55 parts for sale. Got a good deal on a driver side widow as mine was cracked in a million places. 10 Bucks can't go wrong with that. I also fittle-farted with the dang window handle. WHAT A PAIN IN THE $%&*! Finally got it. Not sure what I am doing, but will do a little research here on FTE and I will get through this!!!!!
#97
Damage from MAC's
Rust already forming on the inside.
This is not the correct way to hook it up. Had to switch the wires to make it work properly. Daaahh!
Just for fun. Saw this at a Craft Show that my wife drug me too!
#99
Fall Ride
With harvest in full swing I thought I would go for a short ride today. I put the Hood back so she would look good for a couple of pictures plus it just looks so much better with the "big front" look. All good till I got to the bottom of the hill and it died on me. For some reason it would not restart and I drained the battery trying to restart it. Luckily my neighbor was home and able to pull me back up the hill. So, as my dad did many times, I let it roll back down the hill, popped the clutch and I was off. Still only driving a couple of miles at a time because the "tired" engine. It has never been rebuild, it is covered with oil, blows smoke, and is leaking a lot. I think I will be biting the bullet this winter and pull the engine. As much as I would like to drive it, I think this is in my best interest.
#100
#101
Nice job, coming along nicely. I wonder if your Gramps or Dad had switched over to detergent oil back in the day? By the looks of the inside of your engine maybe not. The new oil you have put in may start to clean all that gunk. I remember my Dad talking about people changing to the new fangled detergent oil and start burning oil, etc because all that gunk was what made the rings seal better....
#103
Set up some temporary tail lights today. Ended up buying all new since it would have cost just about as much as repairing the old ones. The lenses were both broke, gaskets gone, the lamp sockets were all corroded, and the pigtails bare. I will keep the old tail light bodies just in case. Of course they are the original so if I ever have some spare time I might clean them up. Now I am officially road ready. That is unless the law requires the wheels have a cover over them. It's one of the deals were I'll just plead ignorance if stopped!!!!! So far I've driven on the local gravel roads 2-3 miles at a time. Tomorrow I hit the Black Top!
#104
As far as the patch were the mirror is mounted.......it has always been there. It is either an after market add on or something my Grandpa came up with. The patch just re-enforces the mirror. Not sure if I will keep it or try to get mirrors like you have on your truck. I will try to get a better picture for a future post.
Thanks again for sending the Upper Radiator pipe!
#105
I put the hood on myself Abe. I am a big guy plus I'm not to worried because I have lots of Body work to do down the road. I will definitely be more careful when it gets painted.
