steering shaft
Old Aug 6, 2003 | 10:01 AM
Manwith3fords's Avatar
Manwith3fords
Question steering shaft
My upper steering shaft ( between the steering column and the steering box ) has a lot of play in the u-joints. I want to replace it, what years will fit? can you buy a new one for a decent price?
Old Aug 6, 2003 | 11:55 AM
fishin1976's Avatar
fishin1976
steering shaft
You need to get one from a 88-96 as they have the nicer solid rubber rag joint. The junkyard will sell you a decent one for 15-30 bucks. Otherwise, they are about 110 for a brand new one. Thats for a complete shaft assembly.
You can use any 80-96 f150 steering shaft, but the later years are better parts.
Good luck,
Old Aug 6, 2003 | 11:58 AM
Manwith3fords
steering shaft
I forgot to mention, the upper end of the shaft is the worst. is there a rag type joint on this end too? My 63 Merc has a rag joint on the upper end, but my current shaft in the truck has one on the lower end.
Old Aug 6, 2003 | 01:46 PM
fishin1976's Avatar
fishin1976
steering shaft
upper is a u-type joint and the lower is the rag joint.
Old Aug 10, 2003 | 09:04 PM
steve83's Avatar
steve83
steering shaft
'80-91 will fit, but stick with '87-91 for the better rag joint. BTW That's the "intermediate steering shaft"; not the "upper" which is inside the column.
'92-96 is different.
