blinker help 60 f-100
ok, so i got my 60 f-100's headlights, brake lights and parking lights working now. My only problem is that the blinkers do not work. I am pretty sure that the blinker switch is working properly, because when i have the brakes depressed and turn the left blinker on the brake light turns off, and the same thing happens with the right side. I have tried to replace the flasher relay, and it still doesnt work. I have verified that the orange wire to the relay has 12 v and i also have run a jumper between the 2 wires (orange and light blue) that plug into the relay. When i do that, the light will turn on and off (as if the blinker is working), as i touch the 2 wires together. I do not have the factory relay, and my understanding is that the relay is connected to the firewall. What im trying to figure out is if the relay is what would now be a 3 wire flasher relay instead of a 2 wire flasher relay which is in the truck now. I am thinking that the relay may need to be grounded, like the factory relay (connection to firewall could act as a ground). Does anyone know of a relay that will work in the 60? or know if I can retro fit a 3 or 2 wire relay. I have also tried to replace the 2 wire flasher relay and it doesnt do anything either...Any ideas?
I am useing a 2 wire flasher on my 57 and it works fine. If you prob your test light to the blue side of the flasher it should blink very fast(the test light). Than turn the singal one way and see if it works. You may be useing to heavy or to light of a flasher try a 522 flasher.
anyone have a recomendation on an aftermarket fuse panel (no wiring needed) or know where i can buy a fuse panel that i can use? something simple. I dont need a 16 circuit set up. I think a 5 circuit would work, since the only thing the fuse panel seems to run is the lights
I didnt know a 60 had a fuse box my 57 does not and I had a 59 that didn't eather. May be some one added it to yours. All the fuses in these trucks are inline. With new connectors and some new wires you can make it work. But I did see some were some one selling new wire harness for these trucks that plug into the stock stuff. Sorry I cain't remember where.
I had trouble with the lights on my 60, after replacing rear lights (generic external lights on flatbed, needed it anyway) and playing with the wires it turned out to be the fuse contacts on the light switch, and just moving the fuse would return the connection temporarily. A good cleaning and I have had no trouble since. I Pulled A few hairs out before finding that light switch fuse. Specially because I made the mistake of assuming that the problem was in the lights or connections.
Originally posted by laynrubber
This question could be for anyone.....still trying to get the right reply thing down.
Other than 2 fuses on the front of my headlight switch is anything else fused ?
Heater fan or wiper motor ???
In all my crawling around i haven't seen any.
Please share your pics
Well, I went through on my 60 and removed the fuse box. I went to napa, and bought a 18$ generic fuse block, and went to town. the factory fuse box supply's power to only the lights from what I can tell. There ARE 2 wires that came off the fuse box that I dont know what they go to. They are red and black. Both came off of the same fuse, and I havent figured out what exactly they are for yet. It was getting late lastnight, and I decided to call it quits. I am planning on looking at it today, while i reuild my instrument cluster. All of the cardboard in side is missing so any light inside the guage cluster acts as ilumination, instead of an indicator light (such as blinkers)....If anyone wants to see how I did it, or a wiring diagram as to where each wire went on the switch and fuse block , I have it all documented including pics...
