Easy Coolant Question
Old Nov 18, 2015 | 01:55 PM
w_huisman's Avatar
w_huisman
When I open my radiator drain plug / drop the lower hose, how many gallons of coolant can I expect to come out before it stops?
Old Nov 18, 2015 | 02:40 PM
w_huisman's Avatar
w_huisman
Found it... 3-4 gallons... Was buried 5-6 pages deep into the coolant change tech thread!
https://www.ford-trucks.com/forums/9...ml#post9794407
Originally Posted by Beachbumcook
....Will take about 3 - 4 gallons each time you drain and refill... so keep track and buy enough distilled water. I buy 16 - 20 gallons of water to do my complete flush... and this leaves me with 2 - 3 left over in the end so I can top of my system when done.
Old Nov 18, 2015 | 05:39 PM
69cj's Avatar
69cj
Pop the block plugs and almost another gallon.
Old Nov 22, 2015 | 08:53 AM
coolfeet's Avatar
coolfeet
I added a fumoto valve to each side of the 6.0 engine. This made the coolant flush much easier as I drained over 5 gallons each time I flushed. I can open these valves when the engine is hot. Big time saver!
I don't have the fumoto valves on my other Ford van and I drained only 3 1/2 gallons from the radiator pet ****.
GeneLaw1
Jan 20, 2012 04:06 PM
Javo
Mar 26, 2011 11:42 PM
pstrang
Jun 2, 2008 07:32 AM
Lushman
33
Aug 16, 2006 07:52 AM
PSDLOVER
Sep 28, 2003 09:59 PM
