A Little input would be good.
Thanks
Senix asked about you fan, did you verify that works?
Also the BPD oil cooler makes the splits run further apart anyways. You could put a fan on the BPD cooler to help cool the oil there. With temps at 100+ ambient, and 7-8 degree incline it's not going to cool much.
Your theory of bigger radiator making the split bigger isn't necessarily true either. If the block is cooler, so is the oil.
Thanks
Fordteamone
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
05-21-2010 08:19 AM
