Died on road
Old Nov 17, 2015 | 07:57 PM
Absolute's Avatar
Absolute
My next check would be the IPR. Is the nut still there, tight?
Old Nov 17, 2015 | 08:03 PM
JJD's Avatar
JJD
Originally Posted by aawlberninf350
Camshaft
Position
Sensor.
Ford calls it a CMP, but what do they know.
They have a history of going bad, sometimes slowly, sometimes like snapping your fingers.
On edit: and HPOPs are not common failures. More likely causes of sudden loss of Injection Control Pressure (ICP) is a bad Injection Pressure Regulator (IPR) or ICP sensor. Be nice to know the DTC codes they pulled, if you can get those. Or maybe if they say low ICP from a code they pulled, could be something else entirely now and the code is 6 years old. Know the service history? Any chips or tunes on it?
I have a superchip I bought when the truck was new but it's set to economy row. This truck has not even done a brake torque, I'm to tight to buy tires LOL
Old Nov 17, 2015 | 08:09 PM
JJD's Avatar
JJD
I bought a superchip when the truck was new but it's set on economy tow. This truck has never been brake torqued......I'm to tight to buy tires LOL
Old Nov 17, 2015 | 08:30 PM
Rikster-7700's Avatar
Rikster-7700
Could it be an issue with the chip coming loose and possible frying the PCM or other problems? I am not familiar with super chips so I don't know if it connects to the PCM or the OBD II port. Do the dash lights and WTS light come on?
Old Nov 17, 2015 | 08:58 PM
JJD's Avatar
JJD
All lights work it just died while driving. The superchip is a programmer that plugs in under dash and you choose which program to run then unplug. Very old school, 14 years old. I haven't changed programs in years.
Old Nov 17, 2015 | 09:23 PM
Rikster-7700
Ok well that answers that question 😀
F100Gasser
Jan 29, 2019 03:38 PM
dieselcruiserhead
Sep 9, 2009 11:16 PM
cclc1021
Apr 15, 2009 10:39 PM
fast freddie
27
Jul 9, 2007 09:06 PM
Toreador_Diesel
Sep 23, 2005 07:24 PM
