Thanks guys for all your input. Sounds like positive feedback.
Originally Posted by 04fromhell
I know run6.0run put a set on a truck about a year ago i would probably ask him
I was hopping he would chime in as I knew he has some experience with them.
Originally Posted by Maxium4x4
How do I feel..... head gaskets never fail. The stock 5 layer is just fine but if it makes you feel better.... you have a choice.
LOL ask a question get an answer. I guess I was asking more about these being as good or better then the OEM. The general thought here was OEM gaskets and ARP studs is the "best" setup. Well, if I'm going to use the studs then I don't need the bolts the OEM gaskets come with. These are just the gaskets and cost less.
If your going to do push rods i would do the lifters while the heads are off just to be 100% i pulled mine out and checked them and alot of them were really rough so i changed them just to be sure. I also have only used the stock gaskets with the studs. Havent had to open them back up yet. I got mine off ebay it was a kit that came with gaskets studs and stand pipes for i think 700
You cheated cause your engine was already out LOL. No, that would be ideal. To replace all the lifters I would need to separate the motor from the trans and remove the HPOP. Not out of the quesion tho.
