I picked up this truck for cheap about 2 years ago note running. Guy said it jumped time and had pulled it down to the timing set and stopped had new chain for it. so I put it on a trailer and pulled it home and put it in my garage. Replaced chain, cap, rotor, plugs and water pump. Got it to start and went and drove it. Made it about 1 mile from my house and started running poorly. Limped it home.
When I got home I found the exhaust was orange so hosed off the cat and then pulled it in my garage. Went out the next morning and unbolted the cat.
This is were it gets odd. Cranks and fires on a couple cylinders then flat crank. Fuel rail 45psi cranking. Good spark. Numbed my hand and half my arm. So I checked the tfi module on a buddy's truck, good, check pcm cause the injectors are not firing after the first couple fires, it's also good.
I am stumped I am looking for ideas. My only other thought is the o2 sensor. That's the only thing I can think of that will affect fuel.
Has anyone ever had a crank no start do to a o2 sensor?
You might have a bad fuel pressure regulator and a flooded engine.
45psi is too high for the 460 as the max it should be is 39.2psi as most say around 40psi.
Try holding the the throttle at WOT while cranking and see if she starts then.
Ok so I finally got some time to go and look at it. When I put the pcm and tfi module back in a couple weeks ago it fired up but I had to keep the throttle pushed between a 1/4 and 1/2 and then after about a min or 2 died and wouldn't fire.
Put a gauge on the fuel rail and I am sitting around 38-40psi cranking. So that is in check.
I have spark I pulled a plug wire off and it is getting spark.
I did notice when I was moving the distributor There is a clicking noise in one spot. Tracked the noise down and it sounds like a injector clicking. I know the tfi module is good been tested a couple times and ran on a buddy's truck. So I know that is good. Looking for any ideas.
The "clicking noise" is normal.
What you are doing is generating a PIP pulse and the EEC Computer is grounding the coil of the fuel pump relay for one second. The "clicking noise" is the fuel pump relay making and braking.
I would start on a 89 by pulling the EEC Computer out and open it up and see what the caps look like. If they are bad replace them and fix any ate through traces.
I bough a 93 460 super cab long bed the other day and all of its caps were bad. Replaced all of the caps and fixed the vacuum lines and it runs OK now.
