Ontario Chapter Join Chapter>, Leader: loudfords
which battery?
Old Nov 9, 2015 | 12:10 PM
Green Streak's Avatar
Green Streak
which battery?
What battery do you guys recommend for Ontario winters. I am putting it into a 78 f150 with 302.
Old Nov 9, 2015 | 02:35 PM
POPAJON's Avatar
POPAJON
They are all pretty much the same. Cold cranking amps would be one of the first things to look at. Battery dimensions also play a roll. So it is actually what you are running that will be drawing power. I have friends using Optimas, some are running Interstate etc. Pops.
Old Dec 21, 2015 | 09:03 AM
sunuvabug's Avatar
sunuvabug
I've had good luck with the batteries from Costco. I also like the fact you can choose one with a recent manufactured date (just check the sticker ... they are usually the ones at the back of the rack).
seventyseven250
2009 - 2014 F150
16
Jan 5, 2018 09:15 PM
kneisl99
22
Oct 30, 2011 12:07 PM
BlackLabel78
Feb 22, 2010 08:28 PM
jimbo beam
Electrical Systems/Wiring
16
Dec 31, 2006 07:35 AM
bigbadjs
Jan 1, 2004 03:38 AM
