Help Locating Connector Circuits
Old Nov 8, 2015 | 09:31 AM
JWA's Avatar
JWA
2003 E250 full body chassis, gasoline motor..........
Connector C140 is present but capped off and not mated with a male version. Looking over my printed EVTM I physically locate it on the Location Guide Grid, it shows up in the pin outs/faces section too----wire colors matching that portion of the EVTM. Nothing to ID what its intended to connect after manufacture. Photos:
Any help ID'ing the circuits its carries would be greatly appreciated. Unless I'm just plain blind it (so far) can't be found.
Old Nov 10, 2015 | 07:02 AM
Franklin2's Avatar
Franklin2
That's some of your tailer/tow harness.
Orange is the trailer battery charge. It goes to the rear trailer plug and backfeeds through under the dash also.
The grey/red and darkblue should be hanging under the dash either bare wires or in some sort of plug.
The yellow wire is probably a hot wire but I can't seem to find it right away.
Old Nov 10, 2015 | 07:20 AM
JWA's Avatar
JWA
Thank Ya Sir-----question becomes are you finding that in the EVTM and if so what cell? I believe I also have a DVD or CD-ROM EVTM so more info on the C140 is there only it might have to be employed and/or printed.
Old Nov 10, 2015 | 10:46 AM
Franklin2's Avatar
Franklin2
I was looking in Alldata. Looking in the trailer tow section. Your EVTM should have a trailer section to it also.
Old Nov 11, 2015 | 06:02 AM
JWA's Avatar
JWA
My printed EVTM does have Cell 95 pages 1>9 but no where is that C140 connector shown schematically.
I'll keep digging around under the dash for a pass through wire and continuity but much more of this and I'm just drilling another hole!
Old Nov 12, 2015 | 06:59 AM
Franklin2's Avatar
Franklin2
This is the same diagram that I found in Alldata(this is Autozone's). C140 is in the lower right corner, and those wire colors match your wires. You will have to keep looking for the yellow, but I suspect it might be in one of the power distribution diagrams. Yellow is usually a hot wire directly from the battery through a fusible link or fuse.
Old Nov 12, 2015 | 08:13 AM
JWA's Avatar
JWA
Wow---right there plain as day! I wasn't looking at the Modified Vehicle Power portions---my bad.
Thanks sooooooooooooo much Franklin---greatly appreciated!
Whitey5.0
Oct 14, 2017 05:09 PM
Tugly
24
Oct 2, 2017 04:28 PM
Idaho Highboy
Sep 6, 2017 07:44 PM
JWA
Nov 13, 2015 11:44 AM
mierwins
Feb 6, 2009 09:13 PM
