MAP sensor
Old Aug 5, 2003 | 05:56 PM
gotgrouper?'s Avatar
gotgrouper?
MAP sensor
will a bad MAP sensor stop a engine from cranking or running?
thanx, mitch
Old Aug 5, 2003 | 09:58 PM
5_labsownus's Avatar
5_labsownus
MAP sensor
It will not stop the engine from cranking. It should not stop it from running. However if it is bad the engine may not run right. Also if it is bad or vacuum leak to the map. It may run for a few minutes and then die at idle. Weak cylinders causing low vacuum will cause this same proble. You should have 17-24 mmHg at the map. Anything less is a problem. Timing can affect this the same.
