1978 - 1996 Big Bronco
got a few questions!!
Old Aug 5, 2003 | 04:59 PM
bronco351's Avatar
bronco351
Hi guys, I'm going to start gathering parts for the engine build on my 1990 Bronco (5.8L) HO. I just need to know a few things first so i buy the right parts.
My first question is, does my truck use a hydraulic cam?
Secondly, what is the ratio of the stock rocker arms?
Third, does my truck use a TFI ignition system?
Fourth, what is the stock timing set at?
This may sound dumb, what are push rods and what do they do?
Thanks a bunch for all the help!!!
Old Aug 5, 2003 | 06:30 PM
BOJOFASO's Avatar
BOJOFASO
yes your cam is hydrylic lifters
i believe the rocker ratio is 1.6 to 1
yes it is tfi 4
10 degrees before top dead center
your push rod transfer the lift of the cam lobes to the rocker arm which in turn opens and closes the valves.
hope this clears things up
Old Aug 5, 2003 | 06:35 PM
bronco351's Avatar
bronco351
That is exactly what I needed to know! Thanks for all your help.
