Vacuum advance/pick up module issues
Old Nov 5, 2015 | 12:12 AM
Trucker95's Avatar
Trucker95
I replaced the pick module inside the distributor and now the vacuum advance is maxing out too soon causing it to kill the truck once you give it gas. Has anybody else had this problem? Have tried adjusting the vacuum advance and still having the issue
Old Nov 5, 2015 | 02:48 AM
burnthelight88's Avatar
burnthelight88
What engine do you have? What carb do you have? What does the other end of the vacuum line connect to?
If its the stock carb, I believe they all connect to one of the thermal vac switches. If its aftermarket, my understanding is that one or more of the aftermarket makers have a specific port on the carb that the vac advance should connect to.
Old Nov 5, 2015 | 04:32 AM
bigdan1979f-250's Avatar
bigdan1979f-250
You need to time it and see where it's at. May not be your problem, but replacing module warrants it.
Old Nov 5, 2015 | 05:37 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just replacing the pickup module should have had no effect. Make sure one of the vacuum advance springs didn't break or come loose while you were in there.
Old Nov 5, 2015 | 08:28 AM
dlburch's Avatar
dlburch
my money is on a broken wire on the new pickup module. as soon as vacuum moves the advance mechanism, the wire loses contact then no spark...
Old Nov 5, 2015 | 01:07 PM
Trucker95's Avatar
Trucker95
I have a 360 with a 4160 Holley 4 barrel.
Old Nov 5, 2015 | 01:08 PM
Trucker95's Avatar
Trucker95
Went and got a new vacuum advance and still doing the same thing.
Old Nov 5, 2015 | 03:50 PM
bigdan1979f-250
Think about manufacturing tolerances. The pick up is screwed into place, it has not dowel pins or other features to locate it accurately. Plus, the pick up is mounted on a formed sheet metal piece that is also screwed to the body of the dizzy IIRC. Overall, it probably won't affect timing, but if it were me I would double check it.
Old Nov 5, 2015 | 04:12 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Agree he should check timing, but this sounds like something is allowing it to advance too fast. Still too little info. Why was pickup replaced, exactly what ignition is he running. Ignition module and wiring changed every year from 74-76. 77 went to DSII cap and wires, so we have no idea what he is dealing with. Thermal vacuum switch's may be long gone, and no idea what vacuum source he's running. This is why I seldom comment anymore. Not enough info to make an educated guess.
Old Nov 5, 2015 | 06:51 PM
Trucker95's Avatar
Trucker95
1974 f-100 with a 360. Don't know what kind of ignition it is. It has the ignition control module on the fender well and an electronic distributor (does not have points). Got the truck running but it would die after it warmed up so replaced the icm and the pick up module in the distributor. After I replaced the pick up module the timing was messed up so we got the timing correct again. But now when the vacuum advance is hooked up the truck dies when you give it gas.
Old Nov 5, 2015 | 08:29 PM
bigdan1979f-250
Do you have electric or manual choke? Make sure that the choke is shutting off after warming up. Can you gradually raise the rpm or is it just when you mash the throttle?
Old Nov 6, 2015 | 11:54 AM
dlburch's Avatar
dlburch
You got a new vacuum advance or a new pickup module?
Old Nov 6, 2015 | 02:20 PM
Trucker95's Avatar
Trucker95
Electric choke. And no I cannot gradually raise the rpms. Right when you start to give it gas it starts cutting out.
Trucker95's Avatar
Trucker95
I got both. New vacuum advance and pick up module
Old Nov 7, 2015 | 08:16 PM
AerostarDad's Avatar
AerostarDad
This^^^^. I had this exact problem...fixed wire...all is good now.
Carmax
15
Nov 23, 2015 03:44 PM
beartracks
Sep 17, 2015 01:39 PM
Tom Dalessandro
Aug 23, 2015 06:50 AM
7FORD2
Mar 27, 2007 11:01 PM
SwOkcOffRoader
Jul 16, 2005 10:44 AM
