mass air flow system
Old Feb 19, 2002 | 08:20 PM
squidgrouch's Avatar
squidgrouch
Post mass air flow system
I have a 1989 ford bronco 351. I want to change it to a mass air flow system. I also have a c6 trans. Basically I am looking for over all better performance. The engine has been rebuilt with a very mild cam, for towing.
Old Feb 19, 2002 | 09:43 PM
HippieCustoms's Avatar
HippieCustoms
Are you planning on making more mods? Like a bigger cam, different heads etc.? I only ask because if the cam you have now runs good (by good I mean no drivability problems), then the mass airflow won't make it run any stronger. If you plan to make more radical mods, then you will need the mass air. Just my 2c's. Good luck.
Old Feb 19, 2002 | 09:54 PM
slave2dafords's Avatar
slave2dafords
