Exhaust bracket hanger
Old Nov 2, 2015 | 06:30 PM
awq134's Avatar
awq134
Does anyone know where I can get the rearmost exhaust bracket hanger other than the dealership? They want $45 for the darn thing.
The reason I need one is that I had a duel exhaust put on shortly after I bought my truck. It was a flowmaster muffler with some aluminized pipe. it did fine when I lived in North Carolina but after 1 winter in Ohio, the muffler outlet tubes rusted through 60 miles into a 1300 mile round trip to VA Beach and the left tailpipe broke loose.
So there I was, pulled over on an I-76 off-ramp, using an adjustable wrench to remove the only 10mm bolt holding my tailpipe on(very rusty and seized up I might add). 20 minutes later the tailpipe was removed. I would have left it hang, but it was hitting my drive shaft and bouncing off of it quite violently.
So I ordered a dynomax welded stainless steel exhaust this past Friday while I was in VA and installed it this evening when I got home. It looks like the shop that installed my duel exhaust replaced the factory hanger for one of theirs. It works for now, but I had to bend it quite a bit just so my tailpipe didn't rub/melt the plastic trim on the fender. Even a picture of what it looks like would be helpful, I could find something at the local parts store that would work.
Thanks in advance,
Q.
Old Nov 3, 2015 | 11:03 AM
gDMJoe's Avatar
gDMJoe
Lightbulb
Not much solice, however, TASCA has it for $29.74 (-HERE-).
HINT/TIP: The part # is 9L3Z-5260-C - try more extensive research of Google results than I did.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old Nov 6, 2015 | 09:06 AM
awq134's Avatar
awq134
-click- the pic'
Goth 150
That's definitely cheaper than the dealership, but not quite the one I need. That one is for the rear of the muffler and I need the one further back that is closer to the tailpipe.
However I was looking at Pepboys to see if I could find something that would work and low and behold I found an open package buried in the back of the rack that had almost exactly what I need... I think the rubber isolator is a little short at 1 3/4" with the stock one being measured at 2", but it will much lower than the current hanger I have on now. The most important part was the metal bracket that came with it. Judging from the not so high quality picture I found on rockauto.com, it's pretty close to the factory bracket. I just woke up, so i'll report bcak how it works after I change my oil and swap the brackets out.
Old Nov 7, 2015 | 06:31 AM
johnday's Avatar
johnday
Got a photo? I might have what you need sitting in the barn. You pay shipping.
Old Nov 8, 2015 | 04:22 PM
awq134's Avatar
awq134
I really appreciate the offer but I was able to find almost exactly what I needed from pepboys. It worked out really well putting the new tailpipe almost exactly where the stock one was.
Old Nov 8, 2015 | 04:34 PM
johnday's Avatar
johnday
Ah, good deal!!!
Century Coronado
Missouri Chapter
Jan 9, 2007 09:02 PM
keith w
Modular V10 (6.8l)
Jul 3, 2006 01:59 PM
mackman107
Car/truck Buying Advice
May 4, 2006 10:30 AM
04SilverSCFX4
2004 - 2008 F150
May 29, 2005 10:24 PM
kam1685
Dec 17, 2004 01:20 PM
