I have two questions I was hoping someone might be able to
answer for me:
1) What year did the limited slip differential become standard
equipment on the F150?
2) Prior to that year, how can you tell if a F150 has a
limited slip (other than getting a dealer to look up the
VIN number in a computer)?
I'm looking to buy a used truck and am getting conflicting
answers to these questions from various used car dealerships.
I want to get either a 4x4 or limited slip diff. The standard
differential I have now in my 94 F150 drives me crazy in the winter around here.
Yup, hes right... Every Ford differential I've seen has a tag and reads exactly the type of thing he says.
You could also read the code on the door sticker for 'Axle'
The thing is... most of us don't know how to decode them.
Now if we were talking about Fox Cougars, I could tell you all day long what kinda diff the car has without even looking underneath it. But alas, Ford truck axle codes are far different from fox bodied cars. Grab that code though, its under 'Axle' on the tag, then memorize it, its the same as the one in the VIN number I think, and someone might be able to tell you what it is exactly, but then again, thats the door sticker, if the rear end was changed you'd have to go by the tag bolted to the diff cover, its probably all rusted over or nasty and un-readable... its held on by one bolt, unbolt it and throw it in a cup of pepsi for a while.
Your best bet is the diff cover tag, its straight foward and needs no decoding.
The letter H in the axle code on the door sticker should tell you.
19 = 3.55 open diff, H9 = 3.55 L/S for the 8.8 axle
2wd with L/S was never enough for me in the snow because of the steep grade leading to my house. In flat terrain it might be a help. 4x4 rigs are more expensive to buy, mantain and insure, are less comfortable and use more gas. There is a tradeoff.
Ford axle codes from sometime in the early 70's until present, that start with a letter, are factory limited slip units. Those with two digit numbers are non-LS units. As stated by Jim, LS is not standard.
Can anyone point me to a place or places online where I can learn about how differentials work and how to choose what's best for my truck? I have non-LS 3.08 (code "18" on the door sticker-thanks for the info!) in my 98F150 and am thinking I should have a larger ratio to get more power to the ground. Any help would be greatly appreciated!
good site .... 3.08 ... those sound like some "nice" road gears .... if you want larger tired, you should gear it down some , 3.50's would work for 33's on that pickup
