Internal or external Slave?
Old Nov 2, 2015 | 07:50 AM
Nathan Cox's Avatar
Nathan Cox
I bought a s-42. A while back and was wondering does it take external or internal slave cylinder. Has the hole for the clutch fork. So I figured it is external. It's going on a 460.
Old Nov 2, 2015 | 09:54 AM
PlumCrazy7's Avatar
PlumCrazy7
Big block and diesel are external, small blocks are internal.
Old Nov 2, 2015 | 10:07 AM
Nathan Cox's Avatar
Nathan Cox
Does the slave bolt to the bell housing. And where can I get the linkage for the fork?
Old Nov 2, 2015 | 01:40 PM
madpogue's Avatar
madpogue
The slave slides into the u-shaped boss next to the fork opening on the tranny case. When you get the slave (or better, get a pre-built pre-bled master-line-slave assembly; waaay easier to install and no bleeding), you'll see how it clips in.
Not sure what you mean by "linkage". The slave rod moves the fork directly.
cabloom300
Feb 9, 2016 01:34 PM
aikensj
Aug 9, 2015 01:37 PM
IDIDieselJohn
Oct 19, 2014 09:02 PM
FiftyCalUSMC
Nov 14, 2012 10:54 AM
bigredman
Feb 8, 2006 12:25 PM
