Trailer Brake Lighting
Old Nov 1, 2015 | 08:17 AM
ckracing's Avatar
ckracing
I have a 2004 Excursion V10 4x4 I just recently purchased.
Went to hook up my trailer and I only have parking lights no brake lights or turn signals.
So far I've diagnosed it to that I don't have power at the rear connector. 7 pin or 4 flat for these two things.
I've google'd and checked fuses, but most of the googling comes up with an under hood fuse panel that the diesels have and the v10's do not. I've traced the main harness along the frame rail and don't see anything out of the ordinary. I've followed it up the relay boxes under the hood, swapped relays around and still not lights.
I still believe that there is a fuse i'm missing. But I've rechecked and even replaced any trailer fuses relating to lights, but I haven't found one that specifically identifies "trailer stop/turn"
I hate wiring. Any help would be fantastic.
Old Nov 1, 2015 | 12:14 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Fuse # 6. 20 amp, trailer stop/turn. Hope this helps
Old Nov 1, 2015 | 12:39 PM
Stewart_H's Avatar
Stewart_H
To the OP, Vinny the G-man is correct, fuse #6.
Do you have an owners manual? If not, download the pdf version from the link provided in the Excursion Forum Tech Folder sticky thread.
Stewart
Old Nov 1, 2015 | 01:08 PM
ckracing's Avatar
ckracing
Thank you. After finding #6 fuse I also feel like a dumba$$.
So lesson learned and many headaches. Always check fuses with a multi meter.
I replaced a blown fuse with a blown fuse.
All is well again.
Thanks again.
tjworker
6.7L Power Stroke Diesel
May 28, 2015 07:59 AM
fredandfred
Apr 30, 2014 01:15 PM
2horses
15
Oct 30, 2011 04:00 PM
John Puig
Dec 7, 2010 05:20 PM
koboss1
6.4L Power Stroke Diesel
May 11, 2010 09:23 PM
