Yet another tire question?
Old Aug 5, 2003 | 01:31 PM
97expy5_4's Avatar
97expy5_4
As some of you might have read, I'm a brand spanking new(to me) Excursion owner. My truck is in need of new tires, YES I know my door jam states "D" rated tires. My question is:? My X sites fairly high in the air, (tow package etc) I'd like to fill up the wheel wells a little better. I'm currently running 265/75/16. And again I realize that the second tire is a "C" rating, but isn't 5000lbs enough support? Will 315 just be to big?
Thanks
Big Mick
285/75SR16 116Q D 360 B B
3308lbs.
65psi
18/32nds
7.5-9"
8"
11.6"
8.9"
33"
633
315/75QR16 113Q C 360 B B
2535lbs.
35psi
19/32nds
8-10"
8.5"
9.8"
34.5"
605
Old Aug 6, 2003 | 12:36 PM
97expy5_4's Avatar
97expy5_4
I just got the Goodyear Wrangler ATS tires installed on my Excursion. Looks great and rides much better... I ended up getting the 285/75/R16's....
Big Mick
Old Aug 8, 2003 | 07:54 AM
97expy5_4's Avatar
97expy5_4
Well "crap" really does roll down hill.... I just dropped off my X back at the GoodYear Tire shop to get a second set of new tires put on. The Goodyear ATS's were horrible, talk about getting the **** shaked out of me...... . Anyhow now the dealer is installing Dunlop Radial Rover RV tires at a greatly reduced price. He told me that the Goodyears tires are coming from the "warehouse" already shaved due to "out of balance". Just great, I'm leaving to day to drive down to Florida...
Big Mick
Old Aug 8, 2003 | 09:20 AM
jdadamsjr's Avatar
jdadamsjr
Your Ex weighs in at about 7700+ lbs...
your tires NEED that rating and I would want a little 'spare' room...
And then there's the speed rating for the heat you'll generate...
Old Aug 8, 2003 | 10:34 AM
H_E_R_N's Avatar
H_E_R_N
You can find 285's in "D" range on several brand/models....there basic 33x11.50's not too bad for no lift.
Old Aug 8, 2003 | 03:25 PM
guruatbol's Avatar
guruatbol
My X came with 33x12.5x16.5...tires and wheels...
I plan to put 16s back on it when we wear out these new tires it came with...anyhow, the 33" 12.5s look good and we have no lift...
I would like to have 36s but SWMBO is 5'2" and she doesn't wnt here truck to be that tall...
Hope this helps...
Mel
Old Aug 8, 2003 | 07:01 PM
offroadjunkiex's Avatar
offroadjunkiex
parnelli jones dirt grips have the rating and the tread. Quiet ride and stable on the road.
Old Aug 10, 2003 | 02:54 PM
ExcursionUSA's Avatar
ExcursionUSA
Smile Yet another tire question?
I got my new Excursion also with BF Goodrich 33's on it. No lift necessary. Looks a little bit more "beefy" than the factory installed ones.
Ride comfort is good, handeling is good, and cornering is excellent.
Hope that helps.
Old Aug 10, 2003 | 09:51 PM
OGNOM's Avatar
OGNOM
I put on Nitto`s ( 305-70-16`s).No rubbing on stock suspension, no noise, handles a whole lot better. They are $30 to $40 cheaper then B F`s and been reading and hearing they will get you out of the mud and sand where the B F`s can`t.
Old Aug 11, 2003 | 01:04 PM
76Econoline's Avatar
76Econoline
Are you sure your X has 16.5" wheels? In any case, you won't be able to mount 16's on 16.5 wheels, though I'm sure you know that...
Old Aug 11, 2003 | 01:12 PM
guruatbol's Avatar
guruatbol
I was going to buy new wheels...We have been traveling this week to and from LA....these tires ride well..They are a bit wide though...found lots of curb while backing into parking...Parrellel parking an X is an interesting undertaking....
Just wondering about tires....Oh and the wheels are certainly 16.5s....The PO must have changed them out...I am not sure what the reasons would be....I have 16s on my F250...
Mel
Old Aug 11, 2003 | 01:25 PM
76Econoline
Yeah, my '00 X has 16" wheels, but both of the '76 E-250s I've owned came with 16.5" wheels. Finding tires for them was sometimes a challenge.
Old Aug 19, 2003 | 10:07 PM
Btravelen's Avatar
Btravelen
No matter what size or brand tire you use, I would pay attention to the load range. The 'D's are stock and I wouldn't go any lower. I put 'E's on mine.
Old Aug 20, 2003 | 08:51 AM
M Ross's Avatar
M Ross
I have 305's on my X and they rub the inner fender well when making hard left & right turns.
Which is why it is getting a leveling kit next week.
You should be fine with 285 or 295's
