So I bought a 75 f250 highboy from a guy who ended up gutting the whole thing, and as of right now I only have the panel and vents on dash for the air..... I have no a/c,blower, or even air ducts for that matter. Pretty much starting with a blank slate here.
Was I was wondering is what is the best route to go with this? Donor truck or get a complete air system and ducting? right now im working with the 260 air (2 windows down at 60mph) haha
***Also I will mention I have a 95 12v cummins in this truck for the motor, not the old 390
My understanding is that the cummins won't clear the factory AC box, so it might not be possible, but when I swapped mine, I got an entire parts truck of stuff including the wiring, box, dash, etc. If you can afford it, my guess is that an aftermarket one would be the best way.
When I installed AC in my '77 I had a non AC firewall to cut a big hole in ....and I stripped every piece of AC related parts from two donor trucks, a '73 standard cab and a '79 super crew contributed. Then I picked the best from each. I made a template for the big hole from the '79 as well as measured other needed cuts like beside or for lines.
I have an AC cab listed in the classified section.
Im still newer to this site so they wont let me access my inbox or classifieds really. Can you text or call me? 209-482-3220 I have some questions about this
