Orifice Tube ???
Old Oct 31, 2015 | 04:33 PM
Big Red F250's Avatar
Big Red F250
Orifice Tube ???
Starting to trouble shoot the AC. First timer working on a AC. Guessing this will be out of my league mechanically, but what the heck.
Is this where the orifice tube resides.
Thanks
Old Oct 31, 2015 | 08:04 PM
wtroger's Avatar
wtroger
Yep. Take that connection loose and the orfice tube is in the tube. They are pushins with small o'rings. They can be a PITA to get out. There are some tools to do this.
Old Nov 1, 2015 | 11:32 AM
Big Red F250
Thanks wtroger.....
Is the connection threaded ?
Old Nov 1, 2015 | 12:53 PM
pnp522's Avatar
pnp522
It is the same type as the fuel line connections.
Old Nov 1, 2015 | 01:53 PM
tjc transport's Avatar
tjc transport
i ain't rite
yup, that is a spring lock connection. a real pain to get apart sometimes, even if you know what you are doing.
Old Nov 1, 2015 | 03:17 PM
GuitarJesus's Avatar
GuitarJesus
sometimes the spring locks are a total pain especially if they get rusted like yours looks to be a little bit. go ahead and get either a quality Lisle fuel line separator kit, or one from Harbor Freight. they make orifice tube remover tools, but you can use a pair of needle nose pliers if you are careful, but if its a real pain in the butt to get out, just put compressed air in the other side of the line and it will push it right out
Old Nov 2, 2015 | 03:57 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Never heard of using compressed air to help remove it. Plan on replacing the 2 o-rings on the line and lube them with the correct a/c oil for either R-12 (if you can find any or afford it) or most likely R-143a.
My question would be: why do you want to replace just the orifice or is that the only thing you are unsure of?
edit: working on the air conditioning is no different than replacing any other component. Everything is easy to replace except for maybe the evaporator ( I hate pulling heater boxes but have done it a few times as a tech) If the compressor came apart plan on not only replacing the orifice tube/filter but also the accumulator. Depending on how much shrapnel is in the system you might also want to flush out the other parts as best as you can. I do my own a/c work and then take the vehicle to get evacuated and recharged. Paying for the charge is cheaper than buying a good vacuum pump.
gotjeepzj
Aug 18, 2013 12:53 PM
jboehm
22
Oct 2, 2012 12:50 PM
Midnight Star
Aug 7, 2011 10:59 AM
strictly07
Dec 6, 2003 10:02 AM
malcolmw
Jul 23, 2002 09:42 AM
