Missouri Chapter Join Chapter , Leader:77&79F250
RC's November Truck Chat &Turkey Talk Thread
  #136
Old 11-07-2015, 08:44 AM
Grems4ever's Avatar
Grems4ever
Grems4ever is offline
Originally Posted by whiskey runner
ohh i didnt see how the 5speed conversion worked out???
It's in and ready to test hop although the clutch gave me fits to get working.
  #137
Old 11-07-2015, 08:46 AM
Grems4ever's Avatar
Grems4ever
Originally Posted by ldgamblin
Mornin fellas.
Dave, if it had R12 and you're converting to R134a then a flush is a good idea as they use different types of oil. IIRC it's recommended that you have a condenser approximately 10% bigger to have equal cooling abilities. I don't think that you'd ever notice much of a difference except on the hottest and humid of days.
I'm not sure what's in it so I'll flush first just to be safe.
  #138
Old 11-07-2015, 08:58 AM
ldgamblin's Avatar
ldgamblin
ldgamblin is offline
R12 systems have connections like valve stems. R134a have connections similar to air tools.
The retro-fit kits come with adapters to screw onto the schraders to accept the 134a hoses.
  #139
Old 11-07-2015, 09:05 AM
Grems4ever's Avatar
Grems4ever
Got 'em.
Hopefully I'll get started on that this afternoon.
  #140
Old 11-07-2015, 10:25 AM
cyclopsblown34's Avatar
cyclopsblown34
cyclopsblown34 is offline
That's awesome Dave! Now to go home and try to run PEX pipe to my woodstove. And fix the dryer.
  #141
Old 11-07-2015, 10:58 AM
Grems4ever's Avatar
Grems4ever
Arrgh PEX pipe. Nothing sounds so simple but leaves you completely frustrated like PEX.
  #142
Old 11-07-2015, 04:59 PM
BORDERBUM's Avatar
BORDERBUM
BORDERBUM is offline
Let's see if this works.... My power steering needs bled or something, but first video of Bandit driving without shifting issues.
  #143
Old 11-07-2015, 05:41 PM
Grems4ever's Avatar
Grems4ever
What a freaking catastrophe today turned out to be. By the time I got to work on the truck, I was so frazzled that I had to make multiple trips for parts (engine had an idiot light sender on the oil pressure side, o-rings for the AC, and the AC flush. Guess what I discovered after that? A leaky radiator. Should have expected that, but I can't catch a break on anything. Here's the one and only thing that was a step in the right direction all day - and it isn't as pretty as I would like.
  #144
Old 11-07-2015, 06:25 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
looks like you are all bung'ed up dave...ha ha ha ha ha ha .... i dont think i can help ya with the radiator.. my late model stuff is kinnda slim and then i scrapped out the 84 i had out behind the shop..
  #145
Old 11-07-2015, 06:28 PM
whiskey runner
made it up to alans today.. we didn't do anything but stand around flapping our lips.. but i did get some parts dropped off for 'ole rip'.. so that was a step in the right direction i guess
  #146
Old 11-07-2015, 06:49 PM
Grems4ever's Avatar
Grems4ever
No problem RC. I just bit the bullet and got a new one. It's already installed and waiting for me to finish the rest of it.
The next challenge has appeared and I haven't a clue what to do about it. The pipes and mufflers that RC threw in with the rest of the package don't have flat flanges. They are flared at the ends like one would expect with a factory manifold.
I've run out of creative thinking for a while and would appreciate some ideas of how to seal up the exhaust.
  #147
Old 11-07-2015, 07:16 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,323 Likes on 2,472 Posts
Get some cherry bomb (header) mufflers or purple zoomies that bolt direct to the headers. Or get some header flanges and cut off the flare and weld the flanges to the rest of the exhaust sys.
Or... https://jet.com/product/detail/3d597...FZWDaQodA-IHKg
To late now Dave, I am pretty sure I had the radiator from that truck also...
  #148
Old 11-07-2015, 07:20 PM
whiskey runner
all i can think of is a mig..... i forget how they were on the other truck.. was there a exhaust donut gasket in there maybe?
  #149
Old 11-07-2015, 07:40 PM
Grems4ever's Avatar
Grems4ever
Rich - don't fuss about the radiator. If the driver's side pipe didn't run directly under the gas tank and the need for an O2 sensor, the header pipes would be a great solution.
RC - That's about the only way you could get them to work with this set-up.
The way I look at it, I have two choices:
1. I can go spend who knows how long at the local NAPA while they dig through catalogs and dusty boxes in hopes that they might have something that will work.
2. Cut the flares off as clean as I can, mount the flanges on the headers, mock up the rest of the exhaust, tack weld the flanges to the pipes, disconnect them from the header and finish weld them out from under the truck.
The more I think about it, the more I like option #2. I'll have to check to make sure I won't be creating a clearance problem with the transmission crossmember first, but I think that will work. Especially since it means not making another parts run.
Thanks guys...
  #150
Old 11-07-2015, 08:31 PM
Grems4ever's Avatar
Grems4ever
You know something...
Cutting the flare off the ends of the pipe is easy peasy with a chop saw. It's apart and ready for me to clean the surface rust off the pipe for mock-up in the morning.
Quick Reply: RC's November Truck Chat &Turkey Talk Thread
