RC's November Truck Chat &Turkey Talk Thread
#136
#137
Originally Posted by ldgamblin
Mornin fellas.
Dave, if it had R12 and you're converting to R134a then a flush is a good idea as they use different types of oil. IIRC it's recommended that you have a condenser approximately 10% bigger to have equal cooling abilities. I don't think that you'd ever notice much of a difference except on the hottest and humid of days.
#138
#139
#141
#143
What a freaking catastrophe today turned out to be. By the time I got to work on the truck, I was so frazzled that I had to make multiple trips for parts (engine had an idiot light sender on the oil pressure side, o-rings for the AC, and the AC flush. Guess what I discovered after that? A leaky radiator. Should have expected that, but I can't catch a break on anything. Here's the one and only thing that was a step in the right direction all day - and it isn't as pretty as I would like.
#144
#145
#146
The next challenge has appeared and I haven't a clue what to do about it. The pipes and mufflers that RC threw in with the rest of the package don't have flat flanges. They are flared at the ends like one would expect with a factory manifold.
I've run out of creative thinking for a while and would appreciate some ideas of how to seal up the exhaust.
#147
Get some cherry bomb (header) mufflers or purple zoomies that bolt direct to the headers. Or get some header flanges and cut off the flare and weld the flanges to the rest of the exhaust sys.
Or... https://jet.com/product/detail/3d597...FZWDaQodA-IHKg
To late now Dave, I am pretty sure I had the radiator from that truck also...
#149
Rich - don't fuss about the radiator. If the driver's side pipe didn't run directly under the gas tank and the need for an O2 sensor, the header pipes would be a great solution.
RC - That's about the only way you could get them to work with this set-up.
The way I look at it, I have two choices:
1. I can go spend who knows how long at the local NAPA while they dig through catalogs and dusty boxes in hopes that they might have something that will work.
2. Cut the flares off as clean as I can, mount the flanges on the headers, mock up the rest of the exhaust, tack weld the flanges to the pipes, disconnect them from the header and finish weld them out from under the truck.
The more I think about it, the more I like option #2. I'll have to check to make sure I won't be creating a clearance problem with the transmission crossmember first, but I think that will work. Especially since it means not making another parts run.
Thanks guys...
Thanks guys...
#150
