Quick help needed. C1185 2wabs vs 4wabs
Old Oct 28, 2015 | 07:53 PM
  #31
Vitaliykit's Avatar
Vitaliykit
Originally Posted by Pikachu
They may actually be the same physical part with different programming. The service manual does say when a module is replaced, to suck the programming off the module being replaced and paste it into the new one.
So, what u r saying is that PCM is not part of the system, just ABS module.
So, let's say, someone has damaged their front sensors, they can just disconnect them and change ABS module and have 2wabs with no codes. Did I understand you correct?
Old Oct 28, 2015 | 07:54 PM
  #32
Zwalters's Avatar
Zwalters
Originally Posted by Vitaliykit
Thank you. Looks like you really like challenges . Going back out to check everything again. There were few torn wires, but I think I found them all and fixed them. Fuses are ok. Which wires should I check for 12v?
Pikachu's procedure tells you how to. But to make it simple try to find a pin on the connector close to 12V to ground. That's module power.
Old Oct 28, 2015 | 10:13 PM
  #33
Vitaliykit's Avatar
Vitaliykit
PROBLEM SOLVED
UPDATE
Thank you all for your suggestions. PROBLEM SOLVED.
At first I checked 12v going to the ABS Module and it checked out OK. (Plug with 2 wires, just in case someone will read this post in the future).
Then I disconnected plug with most wires and drove around the block and checked codes. I lost my speedo, my O/D light started blinking and I pulled code P0500, which is code for VSS. When I turned on ignition with this plug disconnected, abs light came on and never turned off or even blinked.
Second plug I disconnected with 4 wires. Turned on the ignition and abs light came on, blinked off and stayed on. Drove around the block and pulled C1185.
Then I disconnected plug with 2 wires (12v+/-). ABS light came on and never blinked. After driving around the block I lost speedo, abs light on, but no codes. Had to drive around the block few times at different speeds and eventually O/D light started blinking. Pulled P0500 again. Because I got same code as my original problem, after pulling plug with 4 wires, I figured
that had to be the problem. And sure enough, upon closer inspection, my black wire was torn inside. Fixed the wire (will have to get new plug later) and code is gone. Tried both ABS modules (I monkey glued my old Module together) and both PCMs, no code.
Hope this helps someone in the future.
Swisspsd
Jul 20, 2018 04:18 PM
7700Rob
1997 - 2003 F150
Nov 13, 2007 06:52 AM
mdpitt
1997 - 2003 F150
Oct 13, 2007 10:26 AM
ROKNZRX
Mar 23, 2005 07:25 PM
r_b_burg
Nov 9, 2004 04:48 PM
