Tubes going into cat
Old Oct 28, 2015 | 07:49 AM
turbosporsche's Avatar
turbosporsche
So I need a new exhaust on the truck. Both tubes that go into the cat have rotted out. I assume these are from the air pump. That's the cheapest way to do an exhaust. I use the truck for plowing my own driveway and occasionally dump run. Just want something quite. Can I eliminate air pump and plug ports in back of manifolds or should I just buy all new.
Old Oct 28, 2015 | 09:25 AM
Toplait's Avatar
Toplait
What engine and year, what are the state regulations, and do you plan on keeping it street legal?
If not, then remove the Smog pump. Get a shorter belt. Plug all associated vacuum lines. Plug the holes in the cats and heads. Other then that get it fixed.
I would recommend getting it fixed to work properly. You will not gain any power with its removal. Just makes the engine bay easier to work in.
I have mine plugged....on my 5.8L
Old Oct 28, 2015 | 09:29 AM
turbosporsche
It's a 1990 with a 7.5. In ct because it's 20 years old or more no emission tests are required. I just use it to plow driveway and occasionally dump run.
86ford1
Mar 16, 2018 09:13 AM
eco
Aug 20, 2006 08:05 AM
97rangerguy
Jun 29, 2005 03:10 AM
Stokes
Exhaust Systems
May 12, 2003 09:09 AM
aintskeered
Exhaust Systems
Feb 11, 2002 11:05 PM
