LETS SEE YOUR 67 TO 72 PICK UP
#556
#557
#559
The following users liked this post:
#560
#561
Thanks for the compliments; it’s great to share pictures with people that have an appreciation for Ford pickup trucks. I snapped another picture this morning of under the hood. I have spent some extra time on my truck lately since it is going into the local car show this weekend, it’s never been in a car show before.
Having owned this truck for a little over 40 years I have always kept it garaged and clean. It’s a toy and not a work truck.
The rims are original equipment 16” split rims painted in Wimbledon White with silver lock rings. I did not venture too far away from OEM, at least on the outside. This year/model was not available with power brakes, power steering, automatic transmission or the 390ci engine. A lot a people do not realize that Ford was a little behind the times with their options on ¾ ton 4-wheel drives when compared to GM.
I post some more pictures, Thanks again,
Jim
#562
#566
Jim
#568
on
I just dropped this fresh 360 in...then i see that guy with the 390 and i just smh....ha...still...I'm happy with it. [/QUOTE]
If that pretty Red Coil is a MSD if a blaster ll there not recommended to be mount on there sides if oil filled. Cause they will over heat do one of two things
1. push the end out puking oil every where.
2. cut out off & on until the vehicle stalls, once they cool engine may restart and checks out good with an ohm meter.
So don't take it for a test drive or you'll be calling the tow truck like, I had to do just a 1/4 mile from home.
Non of the info paper work said this when. I about mounting it horizontal.
But found that on the Summit site.
Found out the oem Duraspark ll coil have the same specs so just bought a stock coil
Orich.
Orich.
#569
FRICKIN' COOL Rich. Thanks man. Is that not COOL or what? They look like twins in different pants. Tried to REP ya for it but got that spread around more 1st message.
#570
