Oil Pan Plug
Old Aug 5, 2003 | 08:37 AM
bradleyj's Avatar
bradleyj
Oil Pan Plug
I just bought one of those Fram oil pan drain kits that allows you to drain your oil without tools. I bought the size kit that Fram says should fit my '93 351W pan, but the threads are too small. Does anyone know what thread size is on this drain plug?
Old Aug 5, 2003 | 09:19 AM
joners's Avatar
joners
Oil Pan Plug
No clue, but why don't you just take the drain bolt in with you?
Old Aug 5, 2003 | 09:44 AM
bradleyj's Avatar
bradleyj
Oil Pan Plug
Because I want to have the kit already purchased for the next time I change the oil.
Old Aug 5, 2003 | 02:41 PM
billman's Avatar
billman
Oil Pan Plug
Your's should be Fram part number SD2. That is what I bought and it was fine. If that is the one you bought and the threads are small (I take it you went to change it out and it did not fit), then someone changed the pan. You will have to take the plug off and go to the store with it.
