new steering Question?
Old Oct 26, 2015 | 09:38 AM
kev03's Avatar
kev03
My excursion has all new parts in steering. But when I drive it and hit bumps in the road it will go to the left and feel like I is stuck I have to jerk it a little bit to get it to release. Anyone know what causes this I did flush the fluid. Thank You For any help!
new parts include links, tie rod ends, hubs, shocks,
Last edited by kev03; Nov 15, 2015 at 10:24 PM. Reason: should have used search thread for steering problems
Old Oct 26, 2015 | 10:05 AM
holeshotwalt's Avatar
holeshotwalt
Try disconnecting the steering stabilizer and drive it around. If the stabilizer is damaged it may be sticking in one direction, or both.
Old Nov 3, 2015 | 07:23 PM
kev03's Avatar
kev03
Ok! I did as you said and it did not help so I checked the joints on the steering shaft all good. Could this be the gear box like it has a bad gear?
Old Nov 3, 2015 | 07:26 PM
The2003Excursion's Avatar
The2003Excursion
If the ball jpints weren't torqued right, they might be tight, but bound up. Mine were like that too.
Old Nov 3, 2015 | 07:38 PM
kev03's Avatar
kev03
The ball joints were replaced one and a half year ago and this just started a month before my post. When driving down the road it will just start veering left and steering is in straight position. More noticeable when hitting bumps or ruts in the road. Thank you for your thought.
Old Nov 4, 2015 | 05:05 PM
kev03's Avatar
kev03
Ok I took the tie rod off the left side when I did it came straight up and did not move back and forth as I believe it should do. I then tried to move it from left to right and no give. Then I put the nut on the tie rod and hit it with my 3lb hammer and it acted like it was locked in place. not normal to me.
jgavac
Jun 14, 2017 05:24 PM
IrishMike
Nov 29, 2016 05:23 PM
octaneforce
26
Sep 1, 2012 02:04 PM
BlueDiamond
Feb 18, 2009 08:18 PM
climbon
Aug 4, 2007 08:53 PM
