Bought the IDI! Starting issues.
Old Nov 1, 2015 | 10:48 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
if one is leaking,the others are not far behind.you'll more than likely disturb others replacing one.if you get lucky and stop just the one for a while,it will be short lived and you'll just be chasing your tail with leaks for months.it's not worth it.
amazon and summit sell delphi kits (great quality) reasonably priced for about half the price you found.
Old Nov 1, 2015 | 10:53 PM
PlumCrazy7's Avatar
PlumCrazy7
Assuming it failed from age, how far off can the rest be? I replaced all mine, they only leaked intermittently but once is enough when you're in a hurry and the truck doesn't start. Peace of mind is worth 50 to me and type4 kit has plenty of extra pieces.
F250 beat me to it
Old Nov 2, 2015 | 07:06 AM
MR KROGOTH's Avatar
MR KROGOTH
How would one pull codes from this truck?
Is this still EEC-IV, despite having an E4OD?
Old Nov 2, 2015 | 07:24 AM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by MR KROGOTH
Took a peek at it again - this time with a flashlight, getting dark out.
Seems to be seeping from the ends of the plastic cap.
Is it possible to strictly change the o-rings on just this injector? I really dont want to spend 50$+ on a whole return kit just for one injector. I have both HNBR and nitrile based O-Ring sets available, I'm going to try fixing it with that before the full blown kit. Any input?
Do yourself a favor and get the COMPLETE O-ring, cap and return line kit
Old Nov 2, 2015 | 07:29 AM
MR KROGOTH's Avatar
MR KROGOTH
Old Nov 2, 2015 | 07:45 AM
Diesel_Brad
There ya go
Old Nov 2, 2015 | 01:49 PM
madpogue's Avatar
madpogue
There's no EEC-anything; the engine is completely mechanically run. There's an electonic control for the tranny only.
Does the odometer display a number, just not changing? Or is it blank? Until you get the speedometer / odometer working, don't expect it to shift correctly. The tranny control works off the speed signal from the PSOM. If you have an unchanging number, then the VSS on the rear diff is the prime suspect (or wiring / connector). If no number at all, then the PSOM and/or wiring / fuse to it are suspect. Getting that working MIGHT resolve your shifting issues, but start there anyway.
Do you still have a hard brake pedal? That's your vacuum pump, vacuum lines, vacuum "manifold" (really just a "splitter"), etc. Everything else so "dry" on this truck, I'd bet the lines are pretty hosed (no pun intended...).
Old Nov 2, 2015 | 02:16 PM
MR KROGOTH's Avatar
MR KROGOTH
Absolutely no number on odo - no speedo reading either.
I've heard of these digiclusters failing, Am I going to need another IDI cluster/PSOM to make this correct? Wish there was a way to read mileage...
I'll check fuses again tonight, I replaced 7 (!) the other day.
Yeah the brake failure is in the previous owners decision to replace the alternator with a single groove pulley...
So no second pulley to belt up to the vacuum pump
Old Nov 2, 2015 | 06:49 PM
madpogue's Avatar
madpogue
AFAIK, any '92-'97 OBS PSOM should work. There are differences elsewhere in the cluster (tach, obviously), and another PSOM might be calibrated for a different tire size. But it should interchange, and would at least tell you if that's the root of your shifting issue.
"Doctor, it hurts when I do this....." (or, another episode idea for my cable TV show concept - "Previous Owners Do The Darnedest Things".....) Dude musta had one he!!uva right leg.
Old Nov 3, 2015 | 06:42 AM
MR KROGOTH's Avatar
MR KROGOTH
Shouldnt be too hard to find one. I've checked the fuses once but I'll do it again, just to rule out no power. I doubt the PO was driving this thing like this... just not possible.
After that I'll go after VSS in the rear end.
I found an oil change sticker in the corner of the windshield with a faded "295,xxx" miles on it...
Oh dear.
Not only that, but the pedal isnt really even stiff, it just has so much travel to get through to really start slowing it down. I made another pulley night before last, just need to take off the alternator to get an impact on it to break the nut off.
Old Nov 3, 2015 | 08:07 AM
madpogue's Avatar
madpogue
If it's like that with no power boost, then there's probably also a hydraulic issue. Air in the lines, or a leak, or a shot master cylinder. You'll probably find that it'll go right to the floor when you get the power boost restored. Disabling the booster was another fine way the PO masked a likely hydraulic issue.
Old Nov 3, 2015 | 11:49 AM
MR KROGOTH's Avatar
MR KROGOTH
We will see. The PO I bought the truck from isn't the one who worked on it - he bought it at auction for the bed, and sold the rest. So It was whoever owned the vehicle before it was repoed - and by my research it's a felon running from the law
Old Nov 3, 2015 | 12:08 PM
  #28
madpogue's Avatar
madpogue
Maybe he can't stop even if he wanted to.....
Old Nov 3, 2015 | 12:13 PM
  #29
MR KROGOTH's Avatar
MR KROGOTH
Probably not:
Sheriff seeking help locating robbery and aggravated battery suspect
markbr52
May 19, 2024 08:05 PM
Bubba Jones
337
Jul 19, 2017 08:20 AM
dodonne2
53
Oct 30, 2016 12:29 PM
pincorrect
Oct 23, 2011 02:51 PM
Zephyrhills Ford
56
Jan 31, 2011 12:10 PM
