Hi there
In my '98 Ford Explorer High Class from two days I have no front lights , when I switch the light **** to ON position the dashboards lights going ON but the front lights and back lights no working!!! When I push multifunction schwith to Long Lights They are ON ... it's strange .All fuses are good .... Where I should look for some
relasis PLS. Help me
Since you have an export version of the vehicle there are few who would know exactly how your vehicle is wired or fused, but you can check all fuses not only in vehicle but under the hood, then start checking the many relays on the vehicle. Even US versions of the service manuals can be very vague on relay locations. A typical Explorer in the US has relays in the power distribution box under the hood, as well as an auxillary relay box on the passenger side with several relays in it, as well as an auxillary relay box under the drivers side of the dash near the center console, as well as a relay box in the rear quarter panel area. You also have power fuses to power them up. If the power distribution box doesnt have the park lamp relay, then the next probable location would the aux relay box under the dash near the center console. Its also possible to have headlamp switch or wiring problems. Sometimes the best move is just to take it to the dealer and let them hunt down the problem.
