What are these?
Old Oct 22, 2015 | 02:35 PM
SteeIhead's Avatar
SteeIhead
What are these?
Can anyone tell me what these are?
One is attached to the ignition coil, and the other is attached to the voltage regulator.
They look similar, but have different plugs so I assume have different part numbers.
In searching online I have seen the following terminology referencing them (resistor, capacitor, noise reducer...). I have found some items under capacitor that look similar, but the selection is huge and I couldn't find anything htat had a plug to match the one bolted to the ignition coil....I want to make sure I replace these with the correct replacement part.
Any help would be very appreciated! Thanks!!!
Old Oct 22, 2015 | 02:41 PM
SteeIhead's Avatar
SteeIhead
they are small bullet looking items, with one wire coming out of the point of the tip.
Old Oct 22, 2015 | 03:10 PM
ctubutis's Avatar
ctubutis
Condensors aka capacitors, to prevent radio interference - alternator whine, distributor crackling, whatever.
Old Oct 22, 2015 | 10:48 PM
SteeIhead's Avatar
SteeIhead
I took the one off the coil to try to clean the end of it and see a part number and when I did the wire simply broke off, so now I definily need to replace it. Looking at the part number it looks like it is no longer available.
can anyone tell me of a current replacement part that meets/exceeds the specs of the original?
Thanks!!
Old Oct 23, 2015 | 07:43 AM
Gary Lewis's Avatar
Gary Lewis
I wouldn't worry about it unless you hear noise in your radio. Only the V8's got them, so they weren't "necessary". However, if you decide you need one head to the salvage.
Old Oct 23, 2015 | 08:29 AM
73XAFalcon's Avatar
73XAFalcon
You can still buy those. Check out Dearborn Classics, Autokrafters, etc,.....
Here's one from Tony Branda:
1966 Mustang Radio Noise Suppressor
Old Oct 26, 2015 | 03:10 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Remember years ago not only would the signal interfere with your radio but while watching TV I knew when my next door neighbor came and went.
eric8
Feb 15, 2019 09:44 AM
JoePeeper
Jun 26, 2013 03:20 PM
Screamin T/A
Feb 1, 2012 09:09 PM
TexasGuy001
Oct 30, 2008 09:44 PM
kevkel
May 2, 2004 09:28 PM
